Develop Ineo+ 224 - Invalid External Memory while updating Firmware
  • tsbservice
    Field tech
    • 7975
    #16
    Re: Develop Ineo+ 224 - Invalid External Memory while updating Firmware
    What is exactly issue now?
    • mearmi
      • Oct 2010
      • 346
      #17
      Re: Develop Ineo+ 224 - Error Code C-2650
      Machine keeps on rebooting for 2-3 times and then error code appears C-2650
      • mearmi
        • Oct 2010
        • 346
        #18
        Originally posted by mearmi
        Thanks a lot everyone.
        Re seated SSD , Changed the RAM. Updated the firmware. And finally Changed the SSD from Non e Version. But no luck.
        Still same issue.
        Any advice.
        Thanks once again.
        • Bix
          • Apr 2018
          • 1421
          #19
          Data corruption may have occurred between SSD, MFPB and/or PRCB. Also I'm not sure that Develop has the same firmware as Konica Minolta, even if the model is identical.
          • tsbservice
            Field tech
            • 7975
            #20
            Originally posted by Bix
            ... Also I'm not sure that Develop has the same firmware as Konica Minolta, even if the model is identical.
            Hmm that may be something. For newer models like 8 series FW from KM should work on Develop analog but on 4 series?
