Develop Ineo+ 224 - Invalid External Memory while updating Firmware
  • mearmi
    • Oct 2010
    • 350
    [Misc] Develop Ineo+ 224 - Invalid External Memory while updating Firmware
    Develop Ineo+ 224 -
    Getting Error - This is Invalid External Memory while updating Firmware.
    For other machines same USB works fine. Even tried another USB but same error.
    Please advise.
    Thanks and Kind Regards,
  • mascan42
    • Oct 2008
    • 485
    Re: Develop Ineo+ 224 - Invalid External Memory while updating Firmware
    Was anything done before updating like replacing boards or HDD? Also, make sure you're formatting the USB drive before copying firmware.
    • Synthohol
      Certified Konica Expert
      • 5888
      id try backing up the addressbook and do a full data clear.
      reenable the HDD and load movie data.
      it usually takes FW after that.
      /.02
      • tsbservice
        Field tech
        • 8049
        Agree with above replies. If pre-history depends on what is it. If nothing was done prior I will just follow what Synthohol suggested. Side note, make sure you've correct FW for the model.
        • mearmi
          • Oct 2010
          • 350
          /.02
          Can I have FW and Movie Data
          Many Thanks
          • mearmi
            • Oct 2010
            • 350
            Nothing replaced. Yes formatted the usb .
            • mearmi
              • Oct 2010
              • 350
              /.02
              Can I have the latest firmware and Movie Data
              Thanks a lot
              • Synthohol
                • 5888
                is the konica equivalent a 224e? there was no 224 non e.
                • SMARTENGCENTER
                  • May 2020
                  • 22
                  Dear Friend.
                  Can you share the display picture of the copier what exactly you facing the problem.
                  • Synthohol
                    • 5888
                    pm sent
                    • mga
                      Copier Technician
                      • Dec 2010
                      • 1393
                      Konica C224 is Develop +224
                      In my Develop cross ref shows Konica C224e develop +224e
                      Regards Mark
                      • mearmi
                        • Oct 2010
                        • 350
                        You are Right. It is C224 not C224e
                        Anyone has latest firmware and movie file for C224?
                        Many thanks.
                        • tsbservice
                          Field tech
                          • 8049
                          Check your PM in 5 min.
                          • Simza
                            Simza
                            • May 2020
                            • 27
                            Hi Friend,
                            i have face this problem also manytime,
                            you have to check.
                            -formatting the USB (FAT32)
                            -make shure that you have e-version data or normal 4serial FW-data
                            -Dont use Kingstone....USB. U need simple noname USB, because minolta dont check many USBs.
                            Best of luck
                            Stay Safe
                            • mearmi
                              • Oct 2010
                              • 350
                              pm sent
                              Thanks a lot everyone.
                              Re seated SSD , Changed the RAM. Updated the firmware. And finally Changed the SSD from Non e Version. But no luck.
                              Still same issue.
                              Any advice.
                              Thanks once again.
