Bizhub c224 Fax Issue
  • eli
    Not a technician
    • Oct 2014
    • 40
    I got the fax module installed and enabled in service mode. For some reason, not seeing fax settings in administrator options. When fax is sent, it goes out as an email. Tried to restart, disable and enable fax module in service mode, etc. Nothing works. What could be the issue? It is a used machine and previous owners were able to fax. I've seen old logs of faxes going out.
    edit: fax module is installed in slot #1. Slot #1 is enabled in service mode.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4544
    Re: Bizhub c224 Fax Issue
    Do you have the country code set to right country?
    • eli
      Not a technician
      • Oct 2014
      • 40
      I was able to fix it by setting the prefix/suffix settings to off.
