Bizhub 4050 error 9401
  • Bix
    • Apr 2018
    • 1421
    Hi friends, how are you?
    it's been a while since we see each other.
    Today I have a problem with a bizhub 4050. I get the 9401 error and in the manual it refers to "Exposure lamp lighting failure dected".
    Indeed, when I turn on the printer, the scanner lamp makes a movement but does not turn on. The lamp LEDs remain off. Also, I feel a high heat on the left side of the scanner.
    How do you suggest me to proceed? I remember that changing the scanner on these small printers is a nightmare
  • tsbservice
    Field tech
    • 8006
    Re: Bizhub 4050 error 9401
    Hi Bix,
    Did you try to reset internal error via service menu?
    • Bix
      • Apr 2018
      • 1421
      Yes, I also did a trouble reset. I also notice a strange eletronic noise in the printer right part.
      • Albonline
        • Sep 2008
        • 1147
        sorry to say but it looks like thats where you are at.
        • Albonline
          • Sep 2008
          • 1147
          provided nobody has been in there playing with the ribbon cables that is.
          • Bix
            • Apr 2018
            • 1421
            The printer is 3 years old but has been used very little, it only has 2,000 copies. I checked the cables, trying to unplug and reattach without success. The next step is to change the scanner unit and it won't be easy.
            • Bix
              • Apr 2018
              • 1421
              Problem solved by replacing the scanner unit
              • tsbservice
                Field tech
                • 8006
                New or from parts machine. New one is so expensive that I will probably change whole machine.
