Konica Bizhub 4050
  • bcopier2815
    • Oct 2015
    • 42
    Konica Bizhub 4050
    I am a Kyocera Tech, but have a Konica Bizhub 4050 in one of my accounts. It has locked up the screen. I have tried reboot, unhooked from network, disconnected HDD, removed drum and toner, but no help. Any Ideas? I have added a pic of the display.
  • emujo2
    • Mar 2017
    • 1579
    Re: Konica Bizhub 4050
    This can also be caused by a corrupt print job sitting in the print queue..Leave the machine powered up and the network cable installed. Hopefully this is a printer on a server and not 50 individual users, but open the print queue and delete any jobs that may be sitting and waiting..E
    • copier tech
      • 8131
      Try re flashing the firmware looks like its stuck on a corrupt boot up.
      • Bix
        • Apr 2018
        • 1421
        This freeze is very abnormal because there are overlapping frames.
        I have had several bizhub 4050 with a defective screen, but usually the touch did not work.
        Try to dismantle and reattach the monitor. The procedure is very simple:1. Open the black cover on the left side.
        2. Lift display.
        3. Release dsiplay from clip.
        4. Remove the white cover and unscrew the cable.
        Also try to rewrite the firmware and let us know the outcome.
        • CompyTech
          Super Tech
          • Feb 2011
          • 706
          2. Lift display.
          I agree, could be the screen. Had one stop responding to touch, also had one that would never get past "initializing" displayed on screen. Unfortunately for this model you need the screen to update firmware. Had to replace the main board.
          • bcopier2815
            • Oct 2015
            • 42
            I have the manual and firmware, but cannot get into service mode without a working screen so no firmware upgrade unless I am missing a magic way to do it. On the Kyocera's you just put in USB and turn on. I'll try screen next week.
            • bcopier2815
              • Oct 2015
              • 42
              Left machine on over the weekend and came up with 4091(000.00) code so display is good, sounds like board is bricked
              • srvctec
                Former KM Senior Tech
                • Oct 2009
                • 827
                Or according to the SM could be something as simple as bad power at the wall outlet.
                Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
