Develop Ineo+ 224 Error C-2650
  • mearmi
    • Oct 2010
    • 350
    [Misc] Develop Ineo+ 224 Error C-2650
  • tsbservice
    Field tech
    • 8003
    Re: Develop Ineo+ 224 Error C-2650
    mearmi, if your Develop crosses to bizhub C224 then FWs GA8-K5 and GB8-K5 are suposed to deal among other issues with that error.
    Be careful to read attached info before attempting to update FW as there are many restrictions.
    • mearmi
      • Oct 2010
      • 350
      Thanks for your message. Tried updating the firmware (M1). But getting error Invalid Memory. Tried 3 usbs with the same error.
      In Initialization. After clearing all Data : Machines works for 5-10 prints then reboots with the same error code.
      Please advise
      • tsbservice
        Field tech
        • 8003
        Try to update FW with front cover open.
        • mearmi
          • Oct 2010
          • 350
          Tried but didn’t work. Display freezes at 2 bars
          waited for about 30 minutes.
          • mearmi
            • Oct 2010
            • 350
            What do you advise?
            • Synthohol
              Certified Konica Expert
              • 5814
              reseat the SSD board.
              • tsbservice
                Field tech
                • 8003
                Agree, also reseat and clean memory DIMMs.
                • mearmi
                  • Oct 2010
                  • 350
                  Thanks a lot everyone.
                  Re seated SSD , Changed the RAM. Updated the firmware. And finally Changed the SSD from Non e Version. But no luck.
                  Still same issue.
                  Any advice.
                  Thanks once again.
                  • mearmi
                    • Oct 2010
                    • 350
                    [QUOTE=mearmi;1483736]Thanks a lot everyone.
                    Still same issue.
                    Any advice.
                    Thanks once again
                    • Synthohol
                      • 5814
                      other than changing the MFPB as a last resort, run an engine data backup in service mode, backup the address book if allows and use the SSD reset tool following the explicit instructions so to not lose counter data and ensure a proper restore/recovery. (including entering the 2 digit machine type during the process)
                      if you need documentation let me know.
