sc 28-03 bizhub 920
  • sonypoland
    • Oct 2013
    • 29
    sc 28-03 bizhub 920
    The card stops in front of the lower electrode. Toner sensor clean. After removing the electrode the same situation. Maybe someone has ideas about what happened?
  • escalante
    • Sep 2018
    • 115
    Re: sc 28-03 bizhub 920
    Change the threads of the lower crown.
    Enviado desde mi SM-J701M mediante Tapatalk
    • sonypoland
      • Oct 2013
      • 29
      Do you mean electrode attachment?
      • escalante
        • Sep 2018
        • 115
        I hope those images serve you.Screenshot_20200521-160341_Drive.jpgScreenshot_20200521-160354_Drive.jpgScreenshot_20200521-160407_Drive.jpg
        • sonypoland
          • Oct 2013
          • 29
          Ok. I check this Tomorrow. Thx.
          Wysłane z mojego EVA-L09 przy użyciu Tapatalka
          • sonypoland
            • Oct 2013
            • 29
            I disassembled and cleaned the parts. nothing helped. I need to look for parts to replace them.
            • Synthohol
              Certified Konica Expert
              • 5871
              SC28-03 A separation leak is detected.
              After a separation error detection
              signal is detected while in the
              separation ON, up to 5 separa
              tion ON/OFF operations occur in
              succession.
              The main body
              stops immedi
              ately to turn OFF
              the main relay
              (RL1).
              Toner control sensor board
              (TCSB)
              Printer control board
              (PRCB)
              High voltage unit /2 (HV2)
              Transfer/separation charger
              Power feeding contact
              ADU drive board (ADUDB)
              Wiring harness broken
              • sonypoland
                • Oct 2013
                • 29
                The machine has been repaired. I replaced High voltage unit / 2 (HV2). (Part used from BZ 1050) Thanks to everyone for your help.
