Bizhub c360
  • hory_143
    • 23
    Bizhub c360
    Hi,
    i have a mashine i dont know how to get in the System, anyone changed the password,
    have i any other way to get in the system settings?
    I think i need a nvram reset, but i dont have this jig firmware..
    Thanks in advance, for helping..
    Re: Bizhub c360
    Originally posted by hory_143
    Hi,
    what problems are you having?
    do you have a manual?
    • tsbservice
      Field tech
      • 7926
      Re: Bizhub c360
      If you mean CE mode password is changed from default, yes you will need this FW to change it back to default.
      • hory_143
        • 23
        Re: Bizhub c360
        Yes i have the manual but the default pw is changed from the default.
        I have some of firmwares but theese dont change this only the nvram reset and i dont have it..
        • Nexus
          Re: Bizhub c360
          If changed from another customer then need Special JIG file.When update this jig file then need setup machine for first time used check user manual for first time setup procedure.
          • hory_143
            • 23
            Re: Bizhub c360
            Can anyone send me then firmware?
            • copyman
              Owner / Technician
              • Sep 2005
              • 4544
              Re: Bizhub c360
              have you tried all the obvious passwords?
              9272927292729272
              92729272
              12345678
              00000000
              • hory_143
                • 23
                Re: Bizhub c360
                9272927292729272
                92729272
                12345678
                00000000
                Yes that was first was i made
                • truongxuananh
                  • May 2016
                  • 8
                  Re: Bizhub c360
                  i need firware bizhub c280/360 to update please help me my email : truongxuananh1975@gmail.com thanks you
                  • truongxuananh
                    • May 2016
                    • 8
                    Re: Bizhub c360
                    your prolem i think you should change nv ram pw service on it
                    • truongxuananh
                      • May 2016
                      • 8
                      Re: Bizhub c360
                      i need firware bizhub c280/360 to update please help me ,my email :truongxuananh1975@gmail.com thanks you
