C360 - LICENSE ERROR
  • lordamet
    • Apr 2020
    • 17
    Good evening, recently removed the nvram from my bizhub c360 mfp and now I have an error on the screen that says: an error occurred with the license.
    can you help me please. I do not have an MK account so I cannot enter the CE portal to obtain a new license I appreciate any help
  • femaster
    • May 2011
    • 1482
    Re: C360 - LICENSE ERROR
    See this post, works for any of the older models, like your C360:
    Solving "License Error" messages without access to LMS
    • lordamet
      • Apr 2020
      • 17
      Originally posted by femaster
      see this post, works for any of the older models, like your c360:
      solving "license error" messages without access to lms
      are you use this one before??
      • femaster
        • May 2011
        • 1482
        Not this specific serial/code combination, but I have used another combination I found somewhere else on a few machines in the past and it worked fine.
        Just to clarify, you are talking about a "License Management Error" on a C360 (not a C360i), correct? If so, the previous link should work for you.
        Here is another link with a better description. The serial/code combination is the same, but this one might be easier to follow:
        Bizhub C353 "License Management Error"
