Konica minolta c353 problem scan FTP format hard disk
  • enricocopyline
    • Jun 2018
    • 124
    In a konica minolta c353 after the logical formatting of the hard disk i can't scan ftp.
    HD is installed
    what does depend on?
    Re: Konica minolta c353 problem scan FTP format hard disk
    HD is installed
    did you reload the system and others software on the HDD?
    what made you reformat the drive?
    • enricocopyline
      • Jun 2018
      • 124
      I formatted for an error
      what do you mean by reloading the software?
        you are over your head on this job. if you don't understand what " reloading system software is "
        • enricocopyline
          • Jun 2018
          • 124
          I have always formatted hard drives and have always worked quietly after formatting
          you intend to reload the software with the flash card?
          quiet I am able to do everything
          • emujo2
            • Mar 2017
            • 1579
            What was the original error that made you do a HDD format..?
            • enricocopyline
              • Jun 2018
              • 124
              c-d004
              • emujo2
                • Mar 2017
                • 1579
                run the diagnostics..
                Go to [Service Mode] -> [Sate Confirmation] -> [HDD Adjust] -> [Memory Check]
                If they get a NG, replace parts. (See below).
                WORK0 = Replace Standard Memory (DIMM1).
                WORK1 = Replace Expanded Memory (DIMM2).
                FILE0 = 1 Memory of ASIC200 installed in the MFP board.
                  • 14954
                  There isn't any system software to load after a format. Phil may be thinking of a different machine.
                  • enricocopyline
                    • Jun 2018
                    • 124
                    could there be some characters like (_) which are not supported in the 4series and the dpsw needs to be modified?
                      • 14954
                      If it was able to scan via FTP prior to the format there is likely a setting that got cleared. Go back and check all your settings.
                      • enricocopyline
                        • Jun 2018
                        • 124
                        what settings are erased with formatting?
                        • tsbservice
                          Field tech
                          • 8043
                          Clearly you need a manual to start, and no, it's not just a matter of formatting HDD when machine errors.
                            hell I've been able to clear MANY error codes without reformatting a HDD..
                            don't think the OP has told us WHICH error codes popped...
                            he just might have made a BIG MESS from a simple problems.
                            • rrrohan
                              • Sep 2011
                              • 1977
                              what do you mean by cant scan to FTP? does it give a error or is FTP option not available
