Konica minolta c353 problem scan FTP format hard disk
  • enricocopyline
    • Jun 2018
    • 124
    #16
    Re: Konica minolta c353 problem scan FTP format hard disk
    Originally posted by rrrohan
    what do you mean by cant scan to FTP? does it give a error or is FTP option not available
    [ATTACH=CONFIG]45784[/ATTACH][ATTACH=CONFIG]45785[/ATTACH][ATTACH=CONFIG]45786[/ATTACH]
    error
    today it works with ftp on normal pc
    scan to server and to nas does not work
    • Hansoon
      • Sep 2007
      • 3391
      #17
      SMB1/SMB3 issue?
      Hans
      โ€œSent from my Intel 80286 using MS-DOS 2.0โ€
      • rrrohan
        • Sep 2011
        • 1977
        #18
        Originally posted by Hansoon
        SMB1/SMB3 issue?
        Hans
        i assume he is using FTP due to the SMB support being phased out for security. plus i doubt email is a option due to SSL/TLS so really FTP is the only option.
        you could be half asses and scan to the PC that does work then SMB share from that PC to all the others
        • tsbservice
          Field tech
          • 8053
          #19
          Could be wrong but I was told that if you use one PC with SMB1 enabled just to scan from older models, one cannot access this PC shared folder from other SMB1 disabled PCs in the network.
          • rrrohan
            • Sep 2011
            • 1977
            #20
            yeah but he would be using FTP to the one PC that mysteriously works to then share presumably with SMB2 to all other PC's
            • emujo2
              • Mar 2017
              • 1579
              #21
              I may be worng here..but if you format the HDD you also delete any installed SSL certs..Possibly this is why he has the dreaded "it worked before I did this" statement. E
