c253 1101 jam
  • mtcchuck
    • Oct 2016
    • 50
    c253 1101 jam
    Good afternoon
    I have a Bizhub c253 giving me a fit. Jams from tray 1 giving an 1101 code. I have replaced feed tires, addressed the one ways and shafts, cleaned paper feed clutch as well. I have also tried adjusting paper loop. I have used the service mode to check ps 23. The switch does change state every time. When the paper is jammed in the machine it does show the switch is actuated. The paper stops in the exact same spot every time. The paper is in the nip of the timing roller.
    Anyone have any ideas? Can the paper ports be switched between tray 1 and 2 for testing purposes?
    Thanks in advance Chuck
  • rrrohan
    • Sep 2011
    • 1977
    Re: c253 1101 jam
    you say you "addressed" the one ways and shafts. does that mean you cleaned shaft and replaced the A02E561100 clutch.
    Also could be the CL1 clutch. CL2 is same part number so maybe try swapping them around
    • tsbservice
      Field tech
      • 8020
      Re: c253 1101 jam
      Clean or replace registration roller bushings especially if machine counter is high.
      • rrrohan
        • Sep 2011
        • 1977
        Re: c253 1101 jam
        i didnt do much work on the 353 series but did they have reg roller bushing problems too? i only had them on c364. it was real bad i had one roller i could hardly move by hand. they seemed to fixed it by e series
        • mtcchuck
          • Oct 2016
          • 50
          Re: c253 1101 jam
          Thanks for the advice. i will head back over and try the registration bushings and switch feed clutches. As far as addressing shafts i sanded with emery cloth and checked/oiled one way bearing. I wouldnt think it would could be a clutch because it feeds the paper every time but i will sure try. thanks again for the replies!
          • 3ktlc
            • Feb 2018
            • 180
            Re: c253 1101 jam
            Yes, the registration bushings on this model lock up often. Also, The C454/554.
            • Synthohol
              Certified Konica Expert
              • 5846
              Re: c253 1101 jam
              oiled the one way bearing?
              i alcohol the crap out of them to remove every drop of oil so they dont slip. for 21 years and only like 3 out of hundreds failed because the grooves were too worn to compress the shaft.
              IMHO thats counterproductive.
                Re: c253 1101 jam
                +1 I NEVER OILED one way's
                • mtcchuck
                  • Oct 2016
                  • 50
                  Re: c253 1101 jam
                  No kidding? I was always taught to oil one ways. I was told that by our tech rep when i first started this career. (we are kyocera dealer) Ive been oiling them since 1996! Not saying im right though! I was unable to test things i switched between port 1 and 2 today. We are waiting on an image unit. If this doesnt work i will for sure remove oil from one ways and try again. Thanks for all the feedback.
                  • tsbservice
                    Field tech
                    • 8020
                    Re: c253 1101 jam
                    Same here. Always cleaned oneways good with piece of cotton soiled with isopropyl.
                    Never lubed but they do factory come with some oil on them ...imho work good without it.
                    • Synthohol
                      • 5846
                      Re: c253 1101 jam
                      what they come with is a special mineral oil to prevent rust during shipping across the great pond.
                      the oil evaporates with use and ventilation.
                      thats what was explained to me.
                      • rrrohan
                        • Sep 2011
                        • 1977
                        Re: c253 1101 jam
                        if its only jamming from tray 1 wouldnt registration roller bushings cause jams from tray 2 as well
                        • mtcchuck
                          • Oct 2016
                          • 50
                          Re: c253 1101 jam
                          Well...I went back to test machine. As stated before i moved parts from tray 1 to tray 2. With this being said i fully expected tray 2 to jam. I ran 125 from tray 1 and 125 from tray 2 with no jams. LOL I told the customer to call back when it does jam and let me know which tray is involved. thanks for all your help. I will just hold my breath I guess! You guys are great. Have a good Monday
                          • tsbservice
                            Field tech
                            • 8020
                            Re: c253 1101 jam
                            Clasic move I use it everytime I can before ordering parts cuz whe are small(no car parts inventory)
                            Could be better though...but hey my labour and travel time costs less...well duh.
                            • Hansoon
                              • Sep 2007
                              • 3389
                              Re: c253 1101 jam
                              Same here. In the past decades - fighting the Analogs and later the Digitals - I NEVER EVER replaced one ways nor electro magnetic clutches. I blow them out with air, flush them with brake cleaner, blow them out again, scuff up the shafts or plates with finest-of-fine polishing paper clean all again with brake cleaner and that's it. I'm an Indy doing for 95% rentals and the equipment usually will do up to 1 million or even more before machines being replaced with the next generation.
                              Hans
