C308 won't exit power save
  • deputydogg
    • Nov 2015
    • 172
    This machine is about 2 months old. The customer called yesterday and said the screen was blank and the blue light on the power button is blinking, pushing it has no affect. They powered it off/on with main power switch and is back to normal.
    Any suggestions as to what this may be ?
    Thanks,
    Dave
    • 14813
    Re: C308 won't exit power save
    Thanks,
    Dave
    Go into service mode and allow sleep mode to be turned off. Then go into admin mode and turn off sleep mode.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4723
      Turn off sleep mode. Go into serv mode and under sleep tab (not sure sys 1 or 2) select "permit", exit and enter admin mode and turn off sleep. This was a problem with the "4" series and I automatically turn off sleep on all 75-100 of the 4 series I service. Lot less issues since I've been doing that. Leave it to K/M not to have fixed this next series!
      • Bix
        • Apr 2018
        • 1421
        I have noticed that the problem disappears in the 8 series if you deactivate "Turn off secondary power" by setting it to "Energy saving".
        Other tip: It also deactivates the weekly timer from ErP and sets it to "Pause" (better if you completely disable weekly timer)
