7035 IP-421 and Win XP
  • kbushnz
    • Jul 2025
    Hi All
    New user and novice.
    I have purchased a used 7035 with all the options and I am in the process of getting it to print via the IP-421 print controller.
    At present I am using the parallel port interface until I can get it put on my home network.
    But my Win XP pc asks for the driver, which it finds on the net but then asks for the IP-421 Dics 1.
    I never received any disks with the unit.
    Q1 is there anyone who knows where I can get one (download) from the net??
    Q2 has a copy I can purchase (original naturally)
    Or other work a rounds.??
    I plan to run it via the network soon..
    Thanks for you help in advance
    Calvin
    New Zealand
  • copytechman
    • Nov 2008
    • 939
    Try this:
    onyxftp.mykonicaminolta.com/download
    Lots of drivers to be found there!
    Regards!
    A.
    • kbushnz
      Thanks for the Info
      I have already been to this site and tried a few of the drivers for XP.
      The PCL and Postscrip ones seem to work..
      But when I do a test page it just prints off numerous pages of data code.
      And looking at the job list on the copier it just grows and grows when the PC has only sent one page.
      I may need to do something with the controller??
      Any help would be appreciated as I am not going to try and set it up on the LAN if I cant get it to work directly via the parallel port.
      Calvin
      New Zealand
      • kbushnz
        I have found a more interactive web site in Aussie.
        Lets you select the engine type, then controller and finally what OS.
        Nice and easy.
        Worked a treat....
        Now its time for the network setup.
        Below is the link
        Konica Minolta Australia - Print Drivers
        Calvin
        • albano
          • 17
          Hi, I think the problem is ; the controller, IP, there's no chip Adobe installed....no language support fo print some images...or caracters.....only PCL fonts......
          • kbushnz
            Thanks for the info...
            Have got it to function using PCL drivers and across my network.
            Calvin
            NZ
            • Haroldbfix
              • 212
              Originally posted by albano
              hi, i think the problem is ; the controller, ip, there's no chip adobe installed....no language support fo print some images...or caracters.....only pcl fonts......
              i agree this usually happens when a ps file is sent to that controller and the ps chip is not installed. Try printing using a pcl driver and a non ps file and see if it print ok then.
