Konica Minolta C364e Compact PDF Issues
  • skukan
    • May 2019
    • 26
    [Misc] Konica Minolta C364e Compact PDF Issues
    Has anyone run into issues with the Compact PDF setting on the KM machines?
    The issue I am having is when I go into the PDF and crop the images and then delete the cropped areas the files become completely unreadable. This is only happening when I scan as a Compact PDF. I have been trying to post an attachment but the system seems to not let me. It looks like something is happening to the layers possibly? Any help is greatly appreciated.
    Scott
  • srvctec
    Former KM Senior Tech
    • Oct 2009
    • 827
    Re: Konica Minolta C364e Compact PDF Issues
    What firmware is the machine running? Menu>Utility>Device Information
    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
    • qbert69
      • Mar 2013
      • 1152
      Scott
      PDF is a "container format"...sounds like when you crop, you're destroying the "container" formatting...best thing to do is just scan as jpg/jpeg, crop & then compile to pdf. [emoji41][emoji1303]
      Sent from my SM-N950U1 using Tapatalk
      REACH FOR THE STARS!!!
      Konica Minolta Planetariums!
      • copier tech
        • 8174
        Scott
        What program are you using to crop the PDF?
        Have you got access to another printer you can send the same document to?
        • skukan
          • May 2019
          • 26
          Version 7
          • skukan
            • May 2019
            • 26
            Yes, I believe that is the case. I will try that. Too bad so many PDFs have already been scanned. I seem to have found a workaround by sanitizing the PDF and then making the edits. That's worked in one case thus far.
            • skukan
              • May 2019
              • 26
              Adobe Acrobat DC Pro
              • qbert69
                • Mar 2013
                • 1152
                Or if you have Photoshop, you can open & split out the objects to their various layers!!![emoji848]
                • D_L_P
                  Self Employed
                  • Oct 2009
                  • 1196
                  Scott
                  Does it do it with the compact PDF priority set to speed or quality?
                  Sounds like the compact PDF version being created by the copier is not compatible with whatever software you are using to edit the PDF. Can you try editing the PDF from another computer? Or another program, like Foxit PDF?
                  I'd do a firmware update to the KM machine, and update whatever software you use to edit the PDF just to be sure.
                  • qbert69
                    • Mar 2013
                    • 1152
                    Firmware shouldn't be needed. The machine/mfp is doing what it is supposed to be doing which is compiling that container format!!! How that container format is cracked open and modified is the concerning factor!!! As Adobe is the initiator of the PDF Format, they would be my FIRST "go to" to try any kind of PDF manipulation/ modification!!![emoji41][emoji1303]
