C300i - Color Cast on Scans
  • mkonkelz
    • Dec 2019
    • 49
    Hi everyone,
    i have a problem withy my scans having a magenta color cast. This behavior occurs randomly, maybe once out of 10 scans.
    The whole document will have the color cast, it doesn`t matter how many pages, or which settings (resolution e.g.)
    I attached two PDFs with one having the cast and one scanned normally as it should be:
    Normal.pdf
    ColorCast.pdf
    Scanner: DF-714 DualScan
    Firmware: AA2J0Y0-0100-G00-7B(00) - Function Version: 1.0
    Settings are alle pretty much standard. No additional software installed.
  • qbert69
    • Mar 2013
    • 1152
    Re: C300i - Color Cast on Scans
    Originally posted by mkonkelz
    Hi everyone,
    [ATTACH]45906[/ATTACH]
    [ATTACH]45905[/ATTACH]
    Are your scan settings configured for strictly B&W or Auto Color Detection???[emoji848]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
      • 14811
      Hi everyone,
      If you are duplex scanning does it show on side two?
      • mkonkelz
        • Dec 2019
        • 49
        I always scan using auto color detection, so it shows on auto color. I don`t scan B&W.
        • mkonkelz
          • Dec 2019
          • 49
          I need to try this. The scans so far were only one sided.
          Edit: It also appers on the original glass.
          • Cyclops85
            • Jun 2020
            • 14
            Possible CIS asssembly or cable
            • qbert69
              • Mar 2013
              • 1152
              There ya go!!! Sounds like it is flip-flopping between b&w and color during auto detect...set to strictly b&w and see what kind of results you get!!! [emoji41][emoji1303]
              • qbert69
                • Mar 2013
                • 1152
                Possibly a "white balance" calibration issue during auto color/b&w detect. There should be a way to adjust the sensitivity!!![emoji41][emoji1303]
                • Cyclops85
                  • Jun 2020
                  • 14
                  I highly doubt that is a setting issue. It looks like CIS assembly or cable. We used to see this occasionally on the 8 series.
                  • mkonkelz
                    • Dec 2019
                    • 49
                    Okay, i just tried scanning double sided. And it only shows on the 1st side(s).
                    So the DualScan CIS seems not to be affected.
                    Edit: Also it just appered on 4 separate scans in a row, just to disapper on the 5th one, without changing anything or moving the DualScanner.
                    • Cyclops85
                      • Jun 2020
                      • 14
                      What about from the platen?
                      • mkonkelz
                        • Dec 2019
                        • 49
                        It appears from the Platen and the DF.
                        When scanning 2-sided from the DF it`s only on the 1st page.
                        When disabling Auto-Color and scanning B&W only the problem seems to disappear (not sure yet).
                        Sometimes it`s up to 4-5 scan jobs in a row. Sometimes everything seems normal.
                        • Cyclops85
                          • Jun 2020
                          • 14
                          Possible CCD or MFP board. Is the machine brand new? There is a security measure - press stop,1,1,4,4,C in service mode and you need to input the correct date and time at install. Sometimes if this step is missed it will give coloured backgrounding or lines through copies. Have you done this procedure?
                          • qbert69
                            • Mar 2013
                            • 1152
                            See if there is a setting to change auto color detection sensitivity!!! I have used other scanners, not just KM that when B&W is scanned in color, there will be a slight magenta cast which is related to the green sensor array in the CCD array!!! Make sure your glass & white balance strip are CLEAN!!! Check your auto detection sensitivity!!![emoji41][emoji1303]
                            • mkonkelz
                              • Dec 2019
                              • 49
                              It is brand new (1 week old).
                              I will try it out, but the system got set up by the dealer (it had the right date and time configured on delivery).
