C300i - Color Cast on Scans
  • mkonkelz
    • Dec 2019
    • 49
    #16
    Re: C300i - Color Cast on Scans
    Originally posted by qbert69
    See if there is a setting to change auto color detection sensitivity!!! I have used other scanners, not just KM that when B&W is scanned in color, there will be a slight magenta cast which is related to the green sensor array in the CCD array!!! Make sure your glass & white balance strip are CLEAN!!! Check your auto detection sensitivity!!![emoji41][emoji1303]
    Sent from my SM-N950U1 using Tapatalk
    Glass and strip are clean. I will search for an auto detection sensitivity setting and check it.
    Edit: I am scanning color in color. It also appers on a scans with pictures and vibrant colors.
    • qbert69
      • Mar 2013
      • 1152
      #17
      Check the easy stuff before you start replacing parts!!![emoji41][emoji1303]
      REACH FOR THE STARS!!!
      Konica Minolta Planetariums!
      • Albonline
        • Sep 2008
        • 1151
        #18
        It is brand new (1 week old).
        I will try it out, but the system got set up by the dealer (it had the right date and time configured on delivery).
        you paid for a working unit, get the dealer to fix this!
        • qbert69
          • Mar 2013
          • 1152
          #19
          I'd be curious to see what the internal color test page looks like directly from the engine!!![emoji848]
          • mkonkelz
            • Dec 2019
            • 49
            #20
            Prints look fine, and also the test printouts from the service menu for color adjustment look great.
            What test page do you mean?
            • qbert69
              • Mar 2013
              • 1152
              #21
              Ok. Just making sure! Sometimes if D-Min & D-Max are not calibrated correctly, you can have weird things happen!!![emoji41][emoji1303]
              • Albonline
                • Sep 2008
                • 1151
                #22
                this is a color detection issue, do the calibration adjustments if it still persists, most probably poor connection in the ccd circuit, could be ccd optical alignment, bent scanner, misaligned/loose dislodged mirror.
                • qbert69
                  • Mar 2013
                  • 1152
                  #23
                  Think Simple...B&W/Color Auto-detect threshold. Magenta background related to the green sensor in the CCD. I believe he said the magenta toning of the background was consistent across the page![emoji41][emoji1303] Remember!!! He SAID *AUTO-DETECT* was TURNED ON for SCANNING!!!
                  • qbert69
                    • Mar 2013
                    • 1152
                    #24
                    IF the paper you are scanning contains "Optical Brighteners" (additives to make the paper whiter/brighter, mostly towards the blue spectrum, sometimes fluoresing to some degree under a particular light source!!!) it's possible that with the scanner, it is picking up this reflective color cast and (mis)interpreting it as having a "background". In the case of LED's as a light source the color cast they exhibit is called "binning"...
                    A Look at the Past and Future of LED Binning - Lumenpulse
                    • mkonkelz
                      • Dec 2019
                      • 49
                      #25
                      The problem occurs with different papers. Also when scanning recycling paper and newspapers for example.
                      • qbert69
                        • Mar 2013
                        • 1152
                        #26
                        Make a preset for newspapers with the bleed thru removal detect turned on!!! It's under the scanning application choices and should be listed as "Bkgd. Removal" or "Bleed Removal"...you will be able to adjust the amount of background removal!!!
                        • mkonkelz
                          • Dec 2019
                          • 49
                          #27
                          I have tried it with bleed removal and discoloration adjustment both turned off and on. It`s still the same.
                          My standard setting for both would be "off" / 0 Standard.
                          • qbert69
                            • Mar 2013
                            • 1152
                            #28
                            Have you selected and been using the "bleed removal" when scanning newspapers???[emoji848]
                            • qbert69
                              • Mar 2013
                              • 1152
                              #29
                              Just sent you a PM so you can send me a sample via e-mail!!![emoji41][emoji1303]
                              • mkonkelz
                                • Dec 2019
                                • 49
                                #30
                                Normally i don`t use bleed removal, but for test purposes on this i did, and nothing changed.
