Dipswitch prints only black and white 4e
  • Bix
    • Apr 2018
    • 1421
    Hello guys,
    in the past something in this forum had managed to make your printer print in black and white. By chance there is a dipswitch that allows you to do this?
    I don't want to enable authentication or accounts to do this limitation. Is there any trick?
    Thanks!
  • Albonline
    • Sep 2008
    • 1105
    Re: Dipswitch prints only black and white 4e
    Originally posted by Bix
    Hello guys,
    Thanks!
    monochrome driver
    • Bix
      • Apr 2018
      • 1421
      Yes, I've already thought about this. I also wanted the copy function to work exclusively in black and white. I can do it in the authentication setting but I wanted to know if anyone was aware of a dipswitch.
      • Albonline
        • Sep 2008
        • 1105
        no dw that i know of ,only set default copies to blk through user settings.
        • srvctec
          Former KM Senior Tech
          • Oct 2009
          • 827
          Bix,
          I think what you need is Version 1.0.00002_Panel (Panel Customize Tool). It's software made for us techs to set a machine to have the panel display only what the customer wants. I just found out about it from a co-irker and haven't tried it yet but am getting ready to use it to experiment. It's found under the One Stop section of a specific machine and under the Utilities tab. It even works on all the i-series machines.
          Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
          • tsbservice
            Field tech
            • 7696
            Originally posted by srvctec
            Bix,
            Excellent idea it will work. I tried it before and it's easy peasy. You just check boxes for each function what do you want and what don't.
            • srvctec
              • Oct 2009
              • 827
              Yep, super easy. I just tried it and that's one of the coolest things I've learned about copier-wise lately! This opens a whole new way of doing things if customers don't want to use authentication. Of course the main caveats are it's global and control panel only.
              I just did this on one of our C454e's in the office.
              • DigiMan
                • Jan 2013
                • 262
                How did i miss this damn,so many authentication setups for nothing,is this something new or was i completely oblivious to it(im guessing i was)?
                I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
                • emujo2
                  • Mar 2017
                  • 1580
                  I would ask what do you do when the customer says I need color for the moment?
                  • tsbservice
                    Field tech
                    • 7696
                    It's not brand new as I work with KonMin now for third year and saw it at the beginning.
                    • srvctec
                      • Oct 2009
                      • 827
                      Yeah, like I said, that's one of the caveats of it being a global setting. If the customer does want the option to sometimes make color copies, then the only way is using authentication.
                      Edit to add:
                      Well crap!!
                      I just noticed that Bix was talking about printing in the OP which this Control Panel Customize program has nothing to do with. Dammit, I hate when I miss a little detail like that!
                      • tsbservice
                        Field tech
                        • 7696
                        Edit to add:
                        Well crap!! i just noticed that Bix was talking about printing in the OP which this Control Panel Customize program has nothing to do with. Dammit, I hate when I miss a little detail like that!
                        Read again
                        • srvctec
                          • Oct 2009
                          • 827
                          Read again
                          Ha ha! I thought I read copy somewhere. CRS is real!! Well, at least I feel a little better now.
                            • 22808
                            happens to the best of us brother!
                            don't let it get to you.
                            • tsbservice
                              Field tech
                              • 7696
                              ... Well, at least I feel a little better now.
                              You should as I think you're good forum member trying to help fellow tech!
