Konica Minolta Bizhub c224 misdeed 3205
  • mearmi
    • Oct 2010
    • 346
    Konica Minolta Bizhub c224 getting misdeed 3205
    please also find the attached pic. Copier has only done 63k
    SEF paper is running well.
    kindly advise
    thanks
  • copyman
    Owner / Technician
    • Sep 2005
    • 4533
    Re: Konica Minolta Bizhub c224 misdeed 3205
    kindly advise
    thanks
    Looks like the duplex / exit gate is sticking, spring off, etc. Fairly common problem. Think there's a bulletin on this. I'll see if I can dig it up.
    • mearmi
      • Oct 2010
      • 346
      Please advise
      • tsbservice
        Field tech
        • 7912
        By chance did the rear(right in your picture) end of paper hit something?
        Read this thread a lot of good stuff there:
        • Jumping Jack Flash
          • Jul 2009
          • 61
          Please advise
          If for a reason you have a misfeed like in the picture, the reason may be wrong paper control in the output section. this solution usually checks, the electromagnet and mechanism are under the desktop
