Remote panel server settings tab is missing
  • lowrider2025
    • Jun 2020
    • 4
    We did a initialization process (Service Mode> [System 1]> [Initialization]> [Clear All Data] or the clear item in [Clear Individual Data] ) for a c3351. After that created and installed self-signed certificate. But we no longer have the remote panel server settings tab...
    Anyone know how to get it back ?
    We can login to the cs remote care page with (default) CE password.
  • Bix
    • Apr 2018
    • 1421
    Re: Remote panel server settings tab is missing
    HDD Enabled? Firmware version?
    • lowrider2025
      • Jun 2020
      • 4
      Where can I find the information you need ?
      I can see the Box option is missing so maybe HDD is disabled. How can I check and re-enable it ?
      Is this the same procedure for c3351 ?
      Turn on the machine's sub and main power
      switches.
      2. Press the “Utility/Counter” key.
      3. On the [Utility/Counter] screen, touch
      “Details” and press the keys in the following
      order [Stop]+[0]+[0]+[Stop]+[0]+[1] to enter
      [Service Mode].
      4. Touch “System 2”.
      5. Touch “Option”.
      6. Select “Installed” of HDD and touch “OK”.
      7. Turn OFF the Sub and Main power switches.
      Last edited by lowrider2025; 06-22-2020, 03:28 PM. Reason: searched the forum and maybe found an answer...
      • tulintron
        • Jul 2014
        • 668
        switches.
        [Service Mode].
        System 2 >> HDD
        • lowrider2025
          • Jun 2020
          • 4
          And I assume hdd can only be enable from the physical control panel ? Machine is not located at my site...
          Found in service manual: HDD installation setting - default setting: [Installed]
          So why would it be disabled...sigh
          • lowrider2025
            • Jun 2020
            • 4
            MFP Card Version A92E0Y0-F000-GC3-R9-970
            • Bix
              • Apr 2018
              • 1421
              Unfortunately you cannot activate this option remotely since you do not see the remote panel and server settings
              • emujo2
                • Mar 2017
                • 1579
                Normally only SSL ON and CE password enforced are needed to see the Remote Panel settings. Not sure how a missing HDD might affect this, but let us know if this is why the feature went away. E
                • tsbservice
                  Field tech
                  • 8080
                  After Clear all data you should enable HDD in SM. Get someone on the machine to enable it and you may be good to go.
                  • Synthohol
                    Certified Konica Expert
                    • 5922
                    because...
                    that'll do it
                    also your "special" firmware is like 2 years old and not even base FW
                    please upgrade to A92E0Y0-F000-G00-X4 (latest regular FW)
                    • rrrohan
                      • Sep 2011
                      • 1977
                      is CE password enabled, do you need to enter password to enter service mode?
                      pretty sure you cant setup remote panel without password protecting service mode
                      • tsbservice
                        Field tech
                        • 8080
                        True that.
                        • Bix
                          • Apr 2018
                          • 1421
                          Originally posted by Synthohol
                          because...
                          that'll do it
                          I think the G00-X8 will arrive in late June
