Konica C368 Serial Number Error
  • radd
    • Jun 2020
    • 63
    [Misc] Konica C368 Serial Number Error
    I have a refurbished C368, (imported) I think the serial number has been changed.
    I am trying to activate the i-Option LK-101, when I input the serial in the LMS server it says invalid.
    The labels on the back of the machine look legit, but the Serial number field is blank, no sticker under the scanner glass either.
    The Serial listed in Service mode is the only one I can find.
    I don't know if any boards have been changed on it.
    Is it hard coded in the board, or is it possible to get working one from KM, or am I screwed for the i-Option.
    Any help appreciated!
  • emujo2
    • Mar 2017
    • 1579
    Re: Konica C368 Serial Number Error
    C368 came standard with the I-Option..get the machine on the network and able to get ot the outside world, then just enable the I-Option in the network settings. Normally it will contact the LMS server and self activate. There is a 2nd methode if this fails, but it's outside of the normal LMS services..That's why you are getting an error. E
    • Synthohol
      Certified Konica Expert
      • 5847
      the real serial is on the frame inside the RS door and at least one other place. behind tray 1 on the front of the frame i believe.
      if those labels were removed you have a booty machine and i would return it at their cost for selling you a compromised device.
      • radd
        • Jun 2020
        • 63
        Thanks, I thought that it came included, but when I try to activate ( from the MFP ) I get this:
        Validation process failed. Please enter the License code and validate the function.
        Is that a connection error, do i need to enable a proxy to reach it?
        • radd
          • Jun 2020
          • 63
          Thanks I'll check that in the morning!!!
          • emujo2
            • Mar 2017
            • 1579
            404 - ?????????????????????? the s/n and you will get the activation code to use. This can be entered in web connection or service mode. E
            • radd
              • Jun 2020
              • 63
              Thanks,
              I must have the formatting wrong, it connects but just says waiting then blank screen.
              • Synthohol
                • 5847
                so are you just trying to activate the web browser?
                ive got it to work by enabling DHCP and then go into admin mode and activate it.
                if DNS is incorrect it wont work either.
                you can try 8.8.8.8 as a secondary DNS and see if that helps and the gateway IP has to be good.
                also some networks appliances can stop traffic on port 80.
                do you (they) really NEED the web browser? i mean if it has a fiery then its reqd but for day to day use will it even be used?
                • radd
                  • Jun 2020
                  • 63
                  Yes, that's correct.
                  • radd
                    • Jun 2020
                    • 63
                    Thanks, yep need it for fiery and Papercut.
                    I'll try that, gateway is good , I'll add the 8.8.8.8 DNS see if that helps !
                    • Synthohol
                      • 5847
                      ok now i know 100%
                      you cannot activate it through the Fiery.
                      you MUST first connect the emperon controller to the network, activate the license, THEN reconnect the Fiery and just leave the copier on DHCP anyway so it gets its fake 172.17.249.2 address but the copier is accessible from the next IP up from the fiery.
                      thats the answer, im sure of it.
                      • emujo2
                        • Mar 2017
                        • 1579
                        Not sure what happned there..HTTPS://LMS.konicaminolta.com/activate. E
                        • radd
                          • Jun 2020
                          • 63
                          ok now i know 100%
                          Thanks, I didn't have the Fiery on when I tried, no joy though.
                          And going through the LMS/activate webpage doesn't work ( Serial invalid )
                          No numbers on the frame either
                          Is it possible to get a new one from KM, I'll be taking it up with the supplier, just curious if there were any other options.
                          • radd
                            • Jun 2020
                            • 63
                            Thanks, I tried that link but no luck: Serial invalid
                            • jotunn
                              • 618
                              Valid serial numbers for
                              - Konica Minolta Bizhub C368 are A7PU021000001 - A7PU021027801 and A7PU021200001 - A7PU021210900
                              - Develop Ineo+368 are A7PU121000001 - A7PU121001990
                              Check label colour, should be more graphite, than black; and matte, not glossy - similar to the others.
                              Some machines you can buy 2nd hand, are sold without SN on the frame (sometimes fake, but matching the rest), with fake serial number and fake label on the back.
                              These machines come from KM contracts, and had been resold to third parties for scrapping.
                              However some scrappers break the agreement with Konica Minolta and re-market these machines with changed numbers, so that KM cannot easily identify the source.
                              In such case, you can't install i-Option licence.
                              Possible solution:
                              - you can check if there is original SN stored in upper EEPROM on PRCB (EEPROM DIP8 93C86, SN stored in reverse order, between 0x59A-0x5A6)
                              - the second place, you can take a look for SN is service chip under HV board (EEPROM 93C46, reverse order, between 0x70-0x7C)
                              - set original SN back in service mode, then ask (beg rather) politely someone with service manager account in LMS to generate initialization code for your original SN
                              * in your case, you can't use "alternative initialization code" that can be found on this forum, because it will not generate valid encryption keys for LMS
                              In case you can't extract original serial number, it's rather hopeless. In theory you could use any valid SN from above, but it's illegal.
