C451 Bad color when print/copy, but self-test is perfect
  • tsbservice
    Field tech
    • 8020
    #16
    Re: C451 Bad color when print/copy, but self-test is perfect
    Hey Jim, Thanks for your attitude. Seems you're doing a great service for locals.
    I must admit that was sceptical about your particular scenario.
    Turns out to be my bad.
    Kind regards,
    tsb
    • Synthohol
      Certified Konica Expert
      • 5847
      #17
      Lol,I'm 54 by the way
      When a C454 can be bought off lease for less than the cost of a few DV units I just don't see putting money into a machine the manufacturer wants nothing to do with anymore.
      Fwiw my home copier is an EP2030 and when it has an issue it will find a dumpster but it still works to an extent.
      I took it because a customer was tossing it and I volunteered to take it away
      • fatduke
        • Jun 2020
        • 75
        #18
        Hi man,
        so if I could give to you my contribute, first:
        Check consumables life (expecially drums, developer, trasnfer roller, transfer belt)
        Check drum voltage settings in service mode
        Run a sensor check
        Try to switch old drums with a new one
        Use PCL6 Drivers on PC where printer is installed
        It seems there is a kind of connection trouble between machine ad communication.
        Please attach demo page test in UTILITY MODE (the one with bird)
        I hope it can be useful
        • Jim Z
          • Jun 2020
          • 6
          #19
          Originally posted by fatduke
          Hi man,
          Run a sensor check
          FatDuke-
          Thanks for your comments.
          I did get this problem fixed, here's the cure:
          Found a Stabilization Failure when trying to do Graduation adjustments.
          The half-tone printout only used about 1/4 of the page.
          Turns out that dirty patch sensors were to blame.
          I guess these sensors are for Transfer Belt registration.
          After a few passes doing Graduation adjustments, the old girl is back to being wonderful.
