How to print a multiple page sized PDF document
  • Takhnamishvili
    • Mar 2019
    • 53
    Hello guys,
    I wonder if there is some solution about how to print multiple page sized PDF document on AccurioPrint C3070L. For example: I have PDF file with 4 pages, first page is A4, second A5, third A3 and fourth A5. I put A4 paper on 1st tray, A3 paper in 2nd tray, A5 in 3rd tray. I want to print mentioned PDF file so MFP automatically picks up paper according to page sizes, for first page (A4) it picks up paper from 1st tray, for 2nd page (A5) it picks up paper from 3rd tray automatically and so on. Are there any solutions for it?
    Thanks in advance
  • Bix
    • Apr 2018
    • 1421
    Re: How to print a multiple page sized PDF document
    Hi, in the applications section there is Separate Scans. is that what you mean?
    • Takhnamishvili
      • Mar 2019
      • 53
      No, I mean print PDF document, not scanning.
      • Synthohol
        Certified Konica Expert
        • 5854
        set up the job using "insert sheets" and specify page# and tray?
        • emujo2
          • Mar 2017
          • 1579
          Geez, now were teaching basic PDF usage...You know this isn't a KonicaMinolta problem???
          • Takhnamishvili
            • Mar 2019
            • 53
            Can you give me more detailed explanation please?
            • tsbservice
              Field tech
              • 8028
              Yep, like he said.
              • Takhnamishvili
                • Mar 2019
                • 53
                it's useful when printing multiple page sized PDF on one size of paper, for example, if 1st page is A4 and 2nd page is A3, this option will print both of them on same size of paper. My question is different, I need to print A4 page on A4 size paper and A3 page on A3 size paper automatically.
                Edit: Works!
                • emujo2
                  • Mar 2017
                  • 1579
                  I think you are missing something..
                  The option to have everything print on 1 size is the check box above this..If you choose print by PDF page size it will pull from each tray based on the size of the page. If you are getting something different, then you may have a configuration conflict on the MFP..Like trays are designated for special paper are not allowed to pull in AUTO. E
                  • Takhnamishvili
                    • Mar 2019
                    • 53
                    Thank you, I added trays to auto selection in User menu and it started working.
                    • emujo2
                      • Mar 2017
                      • 1579
                      Where do I send the bill???
                      • Takhnamishvili
                        • Mar 2019
                        • 53
                        Send it to Georgia
