Consumable life reminder b287
  • blinxwap
    • Jun 2020
    • 80
    I have already changed life stop setting in service mode and turn off all reminders , also cleared counters but it still displays druk unit k needs to be replaced mc drum is still good 100k copies is there a software switch to turn off life reminder or any setting i have missed for the b287..
    Sent from my SM-A505F using Tapatalk
  • truongxuananh
    • May 2016
    • 8
    Re: Consumable life reminder b287
    if you want , you change new chip on drum unit ( only chip, it is ok )
    • blinxwap
      • Jun 2020
      • 80
      Ill do that
      • Bix
        • Apr 2018
        • 1421
        Messages already present cannot be deleted after making the change. So the chip solution can help you.
        • copier tech
          • 8172
          Don't waste your money on the chips!
          Did you check SW 51 & 55 are set correctly? F0 0C etc.
          • blinxwap
            • Jun 2020
            • 80
            No not yet will check
