Scanning issues
  • robinsonad86
    • Aug 2014
    • 67
    Scanning issues
    Afternoon all hoping someone can help.
    We have a few devices across the e and 8 and range which have suddenly decided to stop scanning to email. All have server auth errors in job log. One customer had a new router put in and one is having to run off a sim card style router and recently swapped sims, in two other locations nothing has changed. The machines ping out to google (8.8.8.8) and all print fine but wont send a scan anywhere. Firmware up to date and same SMTP details work at other locations.
  • Synthohol
    Certified Konica Expert
    • 5863
    Re: Scanning issues
    plug a laptop in the copiers lan cable and try Online SMTP Test - Send and Check your Email Server
    it may help diagnose the connection or the copier as the culprit.
    • robinsonad86
      • Aug 2014
      • 67
      Re: Scanning issues
      Didnt know that could be done thanks
        • 30358
        Re: Scanning issues
        Whats the gateway? Not the correct gateway No sending
        • robinsonad86
          • Aug 2014
          • 67
          Re: Scanning issues
          One thing I didnt check, new router = new gateway?
          • Bix
            • Apr 2018
            • 1421
            Re: Scanning issues
            Hi, a new router may have a new gateway. For example, they usually have 192.168.1.1 but it could be 192.168.0.1 or 192.168.178.1
            What is your mail server? Gmail?
            • robinsonad86
              • Aug 2014
              • 67
              Re: Scanning issues
              Various but atleast two are on gmail
              • Blizzoo
                • Aug 2013
                • 610
                Re: Scanning issues
                Probably you already know that on gmail to work sending emails from MFP you must enable Allow less secure apps in Security settings.
                • Bix
                  • Apr 2018
                  • 1421
                  Re: Scanning issues
                  That's right, make sure to disable security on third-party apps. Sometimes it wakes up automatically
                    • 14874
                    Re: Scanning issues
                    I recently have had several of the 4e and 8 series machines suddenly stop scanning to email. After attempting to troubleshoot I ended up having to go into service mode and initializing the network settings. Be sure to export current settings to thumb drive prior to initializing.
                    • rrrohan
                      • Sep 2011
                      • 1977
                      Re: Scanning issues
                      Wonder why Gmail considers a fairly modern copier less secure
                      Sent from my Nokia 7 plus using Tapatalk
                      • emujo2
                        • Mar 2017
                        • 1579
                        Re: Scanning issues
                        I don't think Gmail considers the MFP unsecure, just some of the old ways we used to connect these things leaving the ports wide open for hacking..We had a college campus that got hacked via port 25 and sent print jobs to every online copier wasting about 25K sheets of paper. They were using unautheticated SMTP:25 Not gmail, but these web based providers have to protect themselves, many small businesses won't upgrade until they have no choice, I still have some customers running Win 2000..You can complain all you want, I will never be able to get my new devcie to scan back to your laptop. E
                          • 14874
                          Re: Scanning issues
                          It is just Google slight of hand. They make it look like security is key, while they sell your information for billions of dollars. Lol
