Remote Panel - Possible to Scan/Fax?
  • fingertipsolutions
    • Jul 2020
    • 3
    Hello all,
    Slightly odd question - is it possible to trigger a Scan / send from the remote panel?
    I have a customer experiencing difficulty with scanning to network folder. The devil's in the detail with this, I'm certain it's a combination of settings on the photocopier (a BizHub C454) and the Windows 10 workstation it's trying to save the scan to.
    The customer is remote, with limited access times on site. I have remote access to the workstation, and setup remote panel with a view to triggering remote scans of nothing on the device, purely to tweak settings and test.
    To my frustration, remote panel allows me to do anything currently on screen, but doesn't allow me to press the hardware scan / fax button that would make this scheme come together.
    Am I missing something? Is there any other way I can remotely trigger a scan to test the functionality?
    TIA - Austin.
  • copier tech
    • 8131
    Re: Remote Panel - Possible to Scan/Fax?
    Originally posted by fingertipsolutions
    Hello all,
    TIA - Austin.
    Although this doesn't answer your question it maybe the solution.
    The C454 only supports SMB v1 so most likely their Win 10 machine had the security patch installed blocking SMB v1 or their IT disabled it etc.
    • rrrohan
      • Sep 2011
      • 1977
      Hello all,
      TIA - Austin.
      yes. you just will need to specify a paper size. also after you finish testing the copier will complain about original left on glass so customer is hopefully smart enough to deal with that message
        • Jul 2020
        • 3
        Thank you. I'm probably being dumb, but can you see from the attached screenshot where I'd "press" to get to the scan dialog?
          • Jul 2020
          • 3
          Although this doesn't answer your question is maybe the solution.
          Thank you, I think that you're right. I need to be able to test such setting changes before I can go back to the customer as say "fixed it".
          -Austin.
          • rrrohan
            • Sep 2011
            • 1977
            [ATTACH=CONFIG]46231[/ATTACH]
            press menu on the far right then scan/fax. Remote panel can be a bit laggy sometimes so once you press a button and it doesnt seem to have registered hit the refresh button (not the browser refresh) to confirm.
            if issue ends up being SMB1 being phased out just switch them to FTP instead. i presume email will possibly not be possible if your SMTP server needs TLS
            • tsbservice
              Field tech
              • 7963
              The C454 only supports SMB v1 ...
              Should be doable with FW version GBF-M0
              • tsbservice
                Field tech
                • 7963
                Hello all,
                TIA - Austin.
                Just done it and it works, different machine though - Bizhub C250i.
