C 308, black spots
  • pinspin
    • Oct 2011
    • 155
    C 308, black spots
    Hello ! The copier prints black spots and the black developer moves into the waste tank. We replaced Black Dev Unit , all Drum Units, Transfer Belt , all Power Supplies. We will be grateful for any advice. Thank.
  • Toxic
    • 690
    Re: C 308, black spots
    Replaced consumables OEM ?
    I would try to check/replace HV board and electric contacts from HV board to DR/DV.
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Was the drum and dev units oem complete units or refurbished also the picture showing is showing developer hasn't been emptied into the waste box
      Regards Mark
      • tsbservice
        Field tech
        • 7635
        Hi pinspin, search for bizhub C224e developer depletion there are numerous threads here also you will find some attached bulletins. Very unfortunate situation though. There was found by one of the greatest KM techs here on C227 series factory damaged LED erase strips empty slowly developer units but on 8 series never heard of that. Anyway I wish you good luck. Will try dig deep when on PC and be more in help.
        • pinspin
          • Oct 2011
          • 155
          all parts are original
          • pinspin
            • Oct 2011
            • 155
            replaced
            • zoool
              • Nov 2016
              • 52
              for me its fuser unit. taki it out and check
              • Toxic
                • 690
                How fuser can affect developer ejection to WTB?
                • tsbservice
                  Field tech
                  • 7635
                  Check these.
                    • 13055
                    Is the black dev unit getting emptied into the WTB, or are you just finding developer in the WTB? These models auto replenish the dev units from the toner, so it isn't unusual to find developer in the WTB.
                    • tsbservice
                      Field tech
                      • 7635
                      Good point but we all know the theory. If developer is on copies or WTB is extra heavyweighted or drum or/and belt is polished then what's next if not dev being pulled?
                      It's so low level troubleshooting(user like) asking tech who replaced that many parts to check fuser or WTB...
                        • 13055
                        I was just trying to get a little more information from the OP. He never said the any of what you wrote above.
                        If all those parts have been replaced with no results it is time to take a step back and start the troubleshooting process again. Just my opinion of course.
                        • tsbservice
                          Field tech
                          • 7635
                          For me your opinion is valuable here. Not there you know where. Just my opinion of course.
                            • 22703
                            I had a C368 that would suck all of the developer out of the cyan developing unit in about 20 seconds. Naturally, I was distressed when the very first image after the new developing unit was nearly void of cyan. Mine turned out to be an HVT issue. =^..^=
                            • pinspin
                              • Oct 2011
                              • 155
