Need help
  • Alie
    • Jul 2020
    • 11
    Need help
    Can someone help me here. I have a Konica Minolta Bizhub C454e, when printing, the colour red is a shadow to the black words and the pictures have more red in colour then the other colours.
    What can I do?
  • qbert69
    • Mar 2013
    • 1152
    Re: Need help
    What can I do?
    Red or Magenta???[emoji848] First of all, apparently your black is not true black but using CMY+K to make black. If you feel the process black print, it will almost feel like a slightly puffed up thermal embossing due to the colors layering. The shadow sounds like it is from mis-registration of the colors magenta away from the other colors. Clean your Intermediate transfer belt registration sensors...finally, too much magenta in pictures? Run process calibration in service mode. Print a test in strictly b&w, then in color. If none of this makes sense to you, do yourself a favor and call a certified technician to check it out for you. [emoji41][emoji1303]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • Alie
      • Jul 2020
      • 11
      Re: Need help
      thanks for your responds there. I will try it.
      • tsbservice
        Field tech
        • 8020
        Re: Need help
        What can I do?
        Maybe provide more info. Some samples?
        • Alie
          • Jul 2020
          • 11
          Re: Need help
          Hi tsbservice,
          I have attached the original file which you can compare with the problem one.
          • Synthohol
            Certified Konica Expert
            • 5849
            Re: Need help
            can you post any smaller images?
            • Hansoon
              • Sep 2007
              • 3389
              Re: Need help
              LOL!
              Not the first time I'm wondering about those utter useless "thumbnails" for judging print quality or finding complications. More useless even when on top of it they are also fuzzy or unsharp.
              Hans
              • Alie
                • Jul 2020
                • 11
                Re: Need help
                Originally posted by Hansoon
                LOL!
                Hans
                The print looks fuzzy and unsharp because of the shadow of the print. The shadow is magenta.
                • Alie
                  • Jul 2020
                  • 11
                  Re: Need help
                  I'm uploading the images but it's not working here.
                    Re: Need help
                    always the one with the ' rapier ' wit! I was going to respond with something likewise as witty!
                    and it would be nice to see LARGER samples and in PDF format
                    • MarioTech
                      • Jul 2020
                      • 48
                      Re: Need help
                      What can I do?
                      Definitely sounds like a registration issue, however the samples you provided aren't that great. Did you run all adjustments and calibrations?
                        Re: Need help
                        https://www.copytechnet.com/forums/f...b3_attachments
                        Attachments and Images
                        How do I attach a file to a post?
                        To attach a file to your post, you need to be using the main 'New Post' or 'New Thread' page and not 'Quick Reply'. To use the main 'New Post' page, click the 'Post Reply' button in the relevant thread.
                        On this page, below the message box, you will find a button labelled 'Manage Attachments'. Clicking this button will open a new window for uploading attachments. You can upload an attachment either from your computer or from another URL by using the appropriate box on this page. Alternatively you can click the Attachment Icon to open this page.
                        To upload a file from your computer, click the 'Browse' button and locate the file. To upload a file from another URL, enter the full URL for the file in the second box on this page. Once you have completed one of the boxes, click 'Upload'.
                        Once the upload is completed the file name will appear below the input boxes in this window. You can then close the window to return to the new post screen.
                        What files types can I use? How large can attachments be?
                        In the attachment window you will find a list of the allowed file types and their maximum sizes. Files that are larger than these sizes will be rejected. There may also be an overall quota limit to the number of attachments you can post to the board.
                        How do I add an image to a post?
                        If you have uploaded an image as an attachment, you can click the arrow next to the 'Attachment Icon' and select it from the list. This will be inserted into your post and can be located where you want it displayed.
                        To include an image that is not uploaded as an attachment and is located on another website, you can do so by copying the full URL to the image, (not the page on which the image is located), and either pressing the 'Insert Image' icon or by typing [img] before the URL and [/img] after it, ensuring that you do not have any spaces before or after the URL of the image. You can insert photos from your albums (?) in this way too.
                        How do I create a new poll?
                        When you post a new thread, you may also have the option to create a poll.
                        This allows you to ask a question and specify a number of possible responses. Other members will then be able to vote for the response they wish, and the results of the voting will be displayed in the thread.
                        An example poll might be:
                        What is your favorite color?
                        • Red
                        • Blue
                        • Yellow
                        • Green
                        • Sky-blue
                        • Pink with yellow spots
                        To create a poll when you post a new thread, simply click the 'Yes, post a poll with this thread' checkbox at the bottom of the page, and set the number of possible responses you want to include.
                        When you click the submit button, you will be taken to the poll creation page, where you can specify the question and the list of responses you want to include.
                        You may also want to specify a time limit for the poll, so that (for example) it stays open for voting for only a week.
                        another good page is our forum rules: https://www.copytechnet.com/forums/misc.php?do=vsarules
                        • Alie
                          • Jul 2020
                          • 11
                          Re: Need help
                          SKMD Printe20072209340.pdf
                            Re: Need help
                            +1
                              Re: Need help
                              [ATTACH=CONFIG]46284[/ATTACH]
                              ok .. what are the life counts on:
                              drums
                              dev
                              belt
                              are you using OEM genuine toner
                              OR
                              compatible
                              have you cleaned the laser slit glass
                              is the machine clean inside
                              as Mario said,
                              run color calibration/registration
                              report back please
