C6501 with C6101.
  • allan
    RTFM!!
    • 5462
    C6501 with C6101.
    C6101 is the scanner not returning home.
    Home sensor tested ok but motor does not run.
    Removed the scanner drive board ICP's ok.
    Used tester to discover there is not 24V form main DC supply.
    So power supply, what else could it be?
    Whatever
    • 23008
    Re: C6501 with C6101.
    Also could be PRCB. PRCB tells the PS to supply the 24vdc, and interprets the data from the scanner HP sensor.
    So there's HP sensor, scanner motor, scanner PWB, PS, and PRCB.
    • allan
      RTFM!!
      • 5462
      Sensor works in sensor check. Motor should be just fine.
      Scanner drive board smells ok and 24V and 5V ICP's check out.
      Removed the power supply print and visibly it looks ok.
      Think its just first in the diagnostics list.
      Fully agree that the PRCB could be the culprit.
      So i will need a DCPS1 and PRCB.
      Its and old machine and not very common around here.
      Did not want to yank on connectors but will start looking to remove 24V loads and check if that leads anywhere.
      Will have to find a parts machine.
      Whatever
      • allan
        RTFM!!
        • 5462
        Anyone knows if there is a way to disable the scanner on a C6501?
        Whatever
        • tsbservice
          Field tech
          • 8019
          Cannot find it also in SM. Checked all ICPs (ICP1, ICP2 or ICP3) on the scanner drive board?
