B005 FAX C227
  • Bix
    • Apr 2018
    • 1421
    B005 FAX C227
    Hi, today a strange mistake on a bizhub C227.
    This printer has been in the field for about 3 years and has a fax card installed. This was only used in the first year, then the customer never used it again.
    For about a week, several B005s have arrived. I have seen that it is a fax card error. How is it possible that it broke without being used? For now I have just disabled it and will monitor if there are other errors in the future.
    Or can this mistake be a sign of something else? For now the printer works well. I also did a self diagnostic before resetting the printer and Sys/Image mem check WORK1 told me N/G
    Firmware: G00-X8
  • tsbservice
    Field tech
    • 8053
    Re: B005 FAX C227
    Bix recheck installation of fax board. I think as now you disable it code won't come back.
    • Bix
      • Apr 2018
      • 1421
      Re: B005 FAX C227
      Yes, I have disabled the fax card remotely, solving the problem. As soon as I have time I will go and see what happened and how it failed
      • copier tech
        • 8202
        Re: B005 FAX C227
        Firmware: G00-X8
        Just because the fax hasn't been used the board can still fail because it has power to it, its always on to receive a fax!
