C364e problems with scanner and access to a web page
  • furius
    • Jan 2018
    • 34
    Hi guys, I have a c364e to which I have replaced the MFPB and the SSD.
    I followed the textbook procedures as usual, but I have a very strange problem.
    If the machine is turned off for a few days once turned on again, it can no longer send the scans to smb/ftp, without returning any errors, and I cannot even access the web panel.
    The only way to get the machine working again is through system clear from the service menu.
    Tests carried out:
    1. mfpb tool reset.
    2. firmware update.
    3.ssd update.
    4. addition of serial scanner in the technical menu.
    Some idea?
    Thanks so much
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: C364e problems with scanner and access to a web page
    You can try jut not turning it off?
    Also don't try to scan until ike 5 minutes after its done booting up.
    Does it have a static IP and DNS?
    After all the stuff you replaced or reset have you made sure the HDD shows as installed?
    What is the error code?
    More info please.
    • tsbservice
      Field tech
      • 8020
      Weak battery?
