Software to reload Fiery for C6500
  • jmandassociates
    • Sep 2008
    • 186
    #16
    What happens is when you turn it on it doesn't show anything on the built in LCD screen at all. You can only see anything when you connect an external monitor.
    • twinax
      • 82
      #17
      Hi,
      How old is your controller?
      There are several causes, and the HDD is one of them, but first you need to check the controller hardware. Do that in this following order :
      Open your controller and check that the power supply is OK (Green led (or red) lighting on the main board).
      After that switch off the controller and remove the main plug.
      Remove all IDE board (like engine interface), remove HDD and memories (note where those ones are placed).
      Remove all external connections (mousse, keyboard, screen...)
      Connect the main plug and switch on the controller, if the main board is correct they are some bips (Ti..TI..ti) to indicate that the memories are out (missing) . It means that our main board is ok. (note : if no bip ! means that: first the power supply can be defect (less expansive) , or the main board itself (more expansive). If a microprocessor is defect it is very hard to know. don't remove this (those) ones.
      Put the memories back. (of course switch off)
      At this step you can connect a screen and check the boot on it, it stops at "No system disk"
      Switch off the controller and replug the HDD unit.
      Switch on, you will heard some noise on DVD reader and also on the HDD, if not the HDD is defect.
      The most of time, in this case the software is not involved that mostly the HDD. (power down at customer site during ripping)
      Of course you need a new HDD and software.
      I hope that this information can help you.
      (Sorry I'm French my english is not quite well).
      Kind regards,
      Twinax
      Remember Murphy's Law.
      • jmandassociates
        • Sep 2008
        • 186
        #18
        I downloaded the 1.1 system software and burned it to a DVD. Booted up the fiery with the DVD in there. it says uncompressing Linux...Ok, Boothing the Kernel. Then it says
        set left margin
        *** ERROR 952 in uidisp_lcdprim.c->uidisp_UIB_Open().327 (38/Function not implemented): Couldn't find the UIB.
        *** Module ... uidisp_private.c
        *** Function uidisp_init_private()
        *** Line .... 240
        **** errno.... 0
        *** error msg Success
        *** ..... UIB open error
        ********** UISERVER*******
        *** Module....uiserver.c
        **** Function.... uiserver_initalizeLCDsupport()
        *** Line.....626
        *** errno...0
        *** errno msg...Success
        ***......uidisp_init() falied.
        THis is what is displayed on the external monitor we connected. The LCD on the fiery doesn't show anything and the LED on the fiery is Orange.
        • jckiaedmy
          #19
          iPhone Ringtone Maker
          iPhone Ringtone Maker provides a brilliant iPhone ringtone maker for iPhone fans. It is a complete solution to help you rip almost all popular videos/audios like divx to m4r iphone ringtone, h264 avc to m4r iphone ringtone, ra to m4r iphone ringtone, wma to m4r iphone ringtone and upload custermized M4R ringtone to iPhone directly without iTunes after the conversion is done.Ecept for these, it can even convert ringtone from songs purchased in iTunes store without any recurring fees, and cut any music segment from video/audio and turn it to iPhone ringtone. The guide of iphone ringtone maker explains how to effortlessly create your own iPhone ringtone from any video/audio files.Firstly, download and install the iPhone ringtone creator software. Then, the chief interface pops up.1. Click the "browse" button right beside the "Input File" label to get the file you want to custermize ringtone in the window that pops up, then click "OK" button. You could see the video/audio file path and name in the textbox.2. Click "play" button to preview the music before creating ringtone and find the portion of it you want to use as your iPhone ringtone. Then drag and drop the start & end slider to clip music segment to convert, or input the start & end time in the corresponding text box directly. 3. decide output destination folder by clicking "browse" button on the right side of the "Local output File" button.4. If you like, check "Export to iPhone" selection to upload output ringtone to your iPhone directly after the conversion is done.5. After all above are finished, click "Generate" button to begin creating your own iPhone ringtone. During the conversion, you can monitor the process with the progress bar at the bottom.wait a hadful seconds, you get your own iPhone ringtone from the loved music. Download iphone ringtone maker here.
          • Albonline
            • Sep 2008
            • 1151
            #20
            this sounds like the motherboard. i have repaired hundreds of fierys and think that you should get a qualified tech out to fix yours. it could turn into a money pit type of thing to try and fix yourself!
            • RRodgers
              • Jun 2009
              • 1947
              #21
              Originally posted by jmandassociates
              Where can I get the software to reload the Fiery for a BizHub C6500.
              They come with it. Look in the box, minus that... you can get it off of Konica's web site under the "system code" area.
              • RRodgers
                • Jun 2009
                • 1947
                #22
                set left margin
                *** Line .... 240
                **** errno.... 0
                *** Line.....626
                *** errno...0
                When you burn the DVD PLEASE BE SURE TO BURN THE DISK AT A LOW SPEED!! I've had some (ok a few) error out when ya burn them "fast" be sure to select a VERY slow speed. Like 2x maybe 4x for a DVD.
                HTH
                • Stirton.M
                  All things Konica Minolta
                  • Oct 2009
                  • 1804
                  #23
                  Just an FYI
                  This thread is almost a year old and likely the guy who needed the help has resolved it by now. Note the most recent activity that reopened this thread was a f'n spammer.
                  "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
                  ---Groucho Marx
                  Please do not PM me for questions related to Konica Minolta hardware.
                  I will not answer requests or questions there.
                  Please ask in the KM forum for the benefit of others to see the question and give their input.
                  • jckiaedmy
                    #24
                    Make your own ringtone for your iPhone for free!
                    iPhone Ringtone Maker offers a glittering iPhone ringtone maker for iPhone fans. It is a ultimate solution to help you rip almost all popular videos/audios like avi to m4r iphone ringtone, mkv to m4r iphone ringtone, mp3 to m4r iphone ringtone, wmv to m4r iphone ringtone and upload personalized M4R ringtone to iPhone directly without iTunes after the conversion is done.Beside these, it can even customize ringtone from songs purchased in iTunes store without any recurring fees, and clip any music segment from video/audio and convertl it to iPhone ringtone. The guide of iphone ringtone maker make it clear how to easily make your own iPhone ringtone from any video/audio files.Firstly, download and open the iPhone ringtone creator software. Then, the leading interface pops up.1. Click the "browse" button just beside the "Input File" label to get the video/audio you want to make ringtone in the window that pops up, then click "OK" button. You can see the file path and name in the textbox.2. Click "play" button to preview the music before creating ringtone and choose the segment of it you want to use as your iPhone ringtone. Then put and put the start & end slider to get music segment to convert, or input the start & end time in the corresponding text box directly. 3. decide output destination folder by clicking "browse" button on the right side of the "Local output File" button.4. If you need, check "Export to iPhone" option to upload put ringtone to your iPhone directly after the conversion is done.5. After all the above are finished, click "Generate" button to start creating your own iPhone ringtone. During the conversion, you can check the process by the progress bar at the bottom.wait a few seconds, you get your own iPhone ringtone from the loved music. Download iphone ringtone maker here.
                    • RRodgers
                      • Jun 2009
                      • 1947
                      #25
                      Ya mean like this guy?!?! LOL
                      • Stirton.M
                        • Oct 2009
                        • 1804
                        #26
                        Exactly! This spaz needs their account deleted.
                        ---Groucho Marx
                        • dljorg
                          • Sep 2009
                          • 93
                          #27
                          The fiery being discussed is probably a very new Pro80. The new type has 6 USB ports on the back; the Pro80 version 1 only had 4 USB's on the back.
                          You will need Fiery version 3.0 for this hardware as the older Fiery versions do not work on this thing.
                          • jemsovic
                            • Jun 2008
                            • 48
                            #28
                            Please help
                            i have tried to update software to 2.0 version and now it does not show in my machine and have tried to look on konica minolta site for software to download older one to try to restore it but no luck. it copies file from usb and then by instruction I shut down fiery pull out usb, switch on machine and then fiery but even after 90 minutes it does not come to life. led show's ff whole time. it's ic 303 with 3 usb on it X3ety2-10. any help is appreciated
                            • jemsovic
                              • Jun 2008
                              • 48
                              #29
                              my bad it's ic-408 and even system from cd v1.1 will not work it gets transferd and then nothing hapens it says dimed on machine
