Konica Minolta bizhub 475 error code E301
  • tsbservice
    Field tech
    • 8020
    #16
    Re: Konica Minolta bizhub 475 error code E301
    Originally posted by serzhmarchuk
    Its actually default password, i was entering it wrong. But there is no firmware upgrade option in service mode. I understand kinoca minolta is different from Lexmark on this issue, but is there a way to do it yourself?
    One advice. As enduser you will need FW from KM and service manual. On this model KM Lexmark's rebadges are very picky to which FW versions you have and how to upgrade them. I wouldn't help even Contributor enduser on this model because one can easily brick the machine. And you're not even being Contributor.
      i have confirmed with a brother... EITHER you can't read -=OR=- you are LYING about having the service manual.
      keep up the lying and NO ONE will help you.
      we can't stand liars here...
      congrats you have earned your first RED CARD.
      • serzhmarchuk
        • Mar 2020
        • 10
        #18
        Do you know how to update the firmware on them? they are not as simple as lexmark to do so, plus i cant even log in to webinterface due to this problem.
        Originally posted by Bix
        Hi, the bizhub 4050/4750 is the first start of Konica Minolta software integration into Lexmark. If you notice, the settings are similar to Konica Minolta printers but I personally consider a bad copy bad. A good integration of the Konica Minolta software I found it only in the next model, therefore in bizhub 4052.
        I have seen several bulletins on network problems and E301/E304. The best advice is to update the firmware to the latest version. I have seen several bulletins on network problems and E301. The best advice is to update the firmware to the latest version. Another bulletin suggests "Change the network speed setting to automatic. (Default: 100 Mbps half duplex)"
        Other solution:
        1. Install the firmware that fixes the issue.
        2. Change to [ON] if [Rank C] of [Internal Error. Auto Cancel] in Service menu is set to [OFF].
        Procedures: [Service Mode]> [System 2]> [Internal Error. Auto Cancel]> [Rank C]
        Change to [ON] if it's set to [OFF]. (Default: ON)
        Supplementary information:
        The interval time from Error occurrence to automatic reboot can be changed by the following Software Switch setting.
        291 bit0: [0]: 60 seconds to automatic reboot. (Default)
        [1]: 10 seconds to automatic reboot.
        [Fixed firmware]
        bizhub 4750/4050
        -> Install A6F730G0705-W99, A6F730G0705-999, or later.
        • serzhmarchuk
          • Mar 2020
          • 10
          #19
          Re: Konica Minolta bizhub 4750 error code E301
          Thank you for your post. If machine is bricked already i would not mind to try. If only firmware can resolve this issue, why not. Biggest problem is that KM does not have firmware on their support page, and from what i heard firmware is only for authorized repair guys. I do have service manual, and i did figure why firmware option was not showing in my service mode.
          Yes I am beginner on this forum, but if solution is found, there are many out there that could see this thread and that would be helpful to them. I heard other people had same problems. So instead of coping on my own and keeping it to myself i thought to help myself and others with this post and possible resolution.
