Konica Minolta Counter by email issue
  • fatduke
    • Jun 2020
    • 75
    Re: Konica Minolta Counter by email issue
    Originally posted by Drummy
    Have you tried a network reset from the service mode? Had a similar issue with scan to email and it fixed it.
    I did it. No fix.
    TY
    • fatduke
      • Jun 2020
      • 75
      Originally posted by femaster
      Lengthy story, skip the first paragraph if you don't feel like heavy reading, but hopefully this will solve your problem...
      Just had a thought here. We tend to pick up a lot of Off-Lease copiers that we refurbish and subsequently lease out to our own customers. During this refurb, we setup and test everything to make sure the machines are fully functional. Similar to your issue, I had come across a couple machines that refused to do any sort of scan to email, always coming back with the message you indicated above, "Server Connection Error". The copier passed through 4 different techs hands, each of us checking everything we could come up with; verifying all settings, authentication credentials, etc., and everything was correct, yet it just would not connect to the mail server. We wrote off the first couple as being unable to scan for whatever unknown at the time reason, despite everything else working. I eventually came across another with the same exact problem and was determined to figure out what was going on. After a LONG LONG troubleshooting session, involving multiple days, I ended up figuring out what the problem was. An expired self-sign SSL certificate installed in the copier. It doesn't necessarily have to be self-signed, any SSL certificate, if expired, will cause this problem.
      Does the copier have an SSL certificate installed? If so, it may be expired. If you don't know it wouldn't hurt to check anyway. If you are using Start TLS or similar in your SMTP settings, an expired SSL certificate in the copier will prevent the copier from connecting to the mail server and always result in a "Server Connection Error" when trying to do any kind of scan/send to email.
      I don't know the way to get to the certificate area through the copier touch panel as I've always done it through the web interface. Since you still have not told us what model you are working on, I've provided instructions for a Cxx4e model, but others should be similar:
      • Browse to the web interface and log in as the Administrator.
      • Select the Security tab, PKI Settings, then Device Certificate Setting.
      • If the device has a certificate installed it will show up here and give you details about it, including when it expires.
      • If it's expired, select Setting, Remove a Certificate, and OK to delete the thing.
      Unless you know that you need an SSL certificate for something, just leave it empty. If you need one, you would know what for, and should know how to install or create a new one.
      Hope this gets you back on track!
      Hi thank you first for your big explanation but I checked certificate, no one inserted, created new one, checked the security voice about "from address ADMIN", but nothing...really I dunno what to do! LOL
      TY!
      • REGSIS
        • May 2016
        • 435
        Originally posted by Bix
        Hi, you start getting email scans to work. If the customer has no firewall, try this:
        1. Make sure the gateway is correct. One technique I often use is to temporarily enable DHCP to get the correct information on the network and then I set the static IP correctly.
        2. Make sure that the DNS come out. Then try 8.8.8.8/8.8.4.4 or 1.1.1.1/1.0.0.1
        3. Make sure the GMAIL settings are correct.
        host name: smtp.gmail.com
        SMTP over SSL 465
        Authentication ON
        4. Make sure your Google Account is activated for access from less secure apps. It also avoids using the same email address for all customers because if Google detects multiple logins from different IPs, it blocks the account.
        See you soon
        Bix
        Bold text above is must do step when using gmail account.
        Go to security menu on gmail account used on machine and turn ON less secure otherwise your e-mail comunication will be rejected.
        • Synthohol
          Certified Konica Expert
          • Mar 2016
          • 5863
          #19
          TY!
          the from address has to match the email account address you used.
          • emujo2
            • Mar 2017
            • 1579
            #20
            What model is this..you may be pissing up a rope on anything older than a e series ( and e series w/o latest f/w) E
