Bizhub C258 high pitch whine when copying/printing
  • Scarekrow
    • Feb 2012
    • 80
    [Misc] Bizhub C258 high pitch whine when copying/printing
    Bizhub C258 high pitch whine when copying/printing done 425k, changed k drum, checked M1 motor & wd40 on bearing, checked transfer belt, 2nd transfer roller and paper feed, checked K dev unit. I have a recording of it but wrong extension to upload here, can email it.
    Thanks.
  • progoffice
    • Nov 2008
    • 334
    Re: Bizhub C258 high pitch whine when copying/printing
    I had something like this on a C284e and for me it ended up being the black DV unit. I was able to do a load check with covers open and pinpointed the noise there. It was not what I was expecting, but I think you're on the right track. You can take the drums out and force the main motor to drive with the front door open and the actuator pushed in so it thinks it's closed. Then you can push on things and see if the noise changes.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4632
      Thanks.
      Does it have the FS-543 finisher? The RU-513 relay units have a known issue with squealing noise. Believe there is a bulletin on it. Not your issue if no finisher
      • Scarekrow
        • Feb 2012
        • 80
        It does sound electrical, I may try swapping it out, thanks.
        • Scarekrow
          • Feb 2012
          • 80
          No finisher, just top feeder and 4 paper draws.
          • progoffice
            • Nov 2008
            • 334
            What I mean by load check is the option in the service mode/state confirmation. This is where you can turn motors on individually for testing purposes - not really referring to an electrical load check. Didn't mean to point you in the wrong direction.
            • tsbservice
              Field tech
              • 7981
              I'm guessing without hearing noise but electrical noise pitch may also comes from power supply.
              • Scarekrow
                • Feb 2012
                • 80
                Ah I see, I did look in state confirm and looked for that but only saw senor check then got side tracked, will check that.
                • Scarekrow
                  • Feb 2012
                  • 80
                  Good idea.
                  • drowranger
                    • Jul 2015
                    • 122
                    what about rego roller bearings and transfer roller holder gears/bearing ..
                    • Synaux
                      • Mar 2012
                      • 1224
                      If it is like the 4 series, it should be in State Confirmation, the trick is to Open the lower front door or the right door to allow you to do the testing, you will need a manual if you do not have one to know what codes to input to run your tests. Good luck
                      • Scarekrow
                        • Feb 2012
                        • 80
                        I put a drop of lube on the 2nd transfer roller bearings, paper feed unit cogs/bearings, reg roller bearings, took out the belt and rolled it to check for noise, its not the fuser cos that is still active as the noise stops as it spits out the paper.
                        • rrrohan
                          • Sep 2011
                          • 1977
                          Be good to hear the recording you have.
                          Can you host it from OneDrive for us?
                          Sent from my Nokia 7 plus using Tapatalk
                          • Scarekrow
                            • Feb 2012
                            • 80
                            Voice 008.m4a - Google Drive
                            • Don N.
                              • Nov 2011
                              • 409
                              "changed k drum"
                              Is the new K drum OEM?
                              Known issue on aftermarket drums. I believe it's the drum cylinder itself. Varying levels of that noise, but almost imperceptible with an OEM. It's a high voltage noise. I would get that out of there, bc we had some last a day, a month, but ultimately make weird lines in feed direction, if not total black page on first copy. We may have had that with an OEM once. Can't remember.
