c360i power save screen
  • Northwestservice
    • Jan 2011
    • 140
    just setting up a new c360i. firmware update done. when machine goes into power save the machine shows a fancy colour screen that says place your announcement here I have searched but cant find where to change announcement anybody seen this and know where to set it ?thank you in advance Terry
  • tsbservice
    Field tech
    • 7975
    Re: c360i power save screen
    Terry, this is KM Marketplace app - MarketPlace.
    You better remove Marketplace see this thread:
    Konica minolta "i" series freezing up.
    Good luck
    • rrrohan
      • Sep 2011
      • 1977
      isnt software switch 172 hex 01 meant to disable marketplace?
      • tech51
        • 846
        • Albonline
          • Sep 2008
          • 1144
          the screen saver will show up even with marketplace disabled, you must turn it off , or live with either a white screen or the message screen until low power mode starts.
          • Northwestservice
            • Jan 2011
            • 140
            sorry for the late response back f ing swamped had 2 machines side by side different low power screen saver 1- Konica Minolta symbol the other market place. disabled it in low power setting and removed the marketplace in classic key setting unset 11 market place seems to be good now thanks people I will be checking soft switch to make sure
