MFC368 - Error code D011 - D050
  • heytony29
    • Aug 2025
    [Error Code] MFC368 - Error code D011 - D050
    Hello,
    I have a BH C368 which Error Code D011 or D050 sometimes occur when turning on SW on or recovering from the sleep mode.
    He is actually running firmware G00-01 (MFP Controller Boot Program for an MFP Card Version G00-54) .
    Following this document : https://cscsupportftp.mykonicaminolt...productid=1816 i saw that Firmware G00-A7 can solve this problem (item 53), do you know where i can find this firmware (or a more recent one) ?
    Thank you,
    Best Regards,
    Anthony
  • copier tech
    • 8174
    Re: MFC368 - Error code D011 - D050
    Originally posted by heytony29
    Hello,
    Thank you,
    Best Regards,Anthony
    Yes this was a known issue with the early 8 series.
    As you say there is a firmware fix for this with either SATA Preventative or Recovery Firmware (see attached pdf)
    SATA Related Errors.pdf
    Drop us an email we can supply it for you.
    Firmware Update - Printer & Copier Firmware
