C364e Printing Grey with slight red.
  • denvertan
    • May 2019
    • 82
    [Misc] C364e Printing Grey with slight red.
    Issue: (Printing Grey Background, printout showing light magenta)
    The whole paper suppose to be in light grey but printout showing slight red it those grey colour area.
    Try to print with design without grey background. Turn out nothing wrong.
    What have been done so far.
    0. Run the Gradation Adjustment (3 times with A3 paper)
    1. Print the pdf in 2 Colour red, gree, blue, cyan, magenta, yellow to check for which colour cause the issue. But all turn out to be normal. No colour discrepency.
    2. Life stop show developer is near end of life, replaced all 4 developer. Redo step 0, issue not fix.
    3. Cleaning the laser (Does not fix the issue too)
    I tried to print the same pdf at other same model copier. They did not show any issue same as this machine.
    Other stop life is 30%. or more.
    The red printout
    The source
    Please suggest what I can check. TQ.
  • qbert69
    • Mar 2013
    • 1152
    Re: C364e Printing Grey with slight red.
    Check your design. Make sure the graphics are completely flattened into 1 single layer & rasterized prior to sending to the printer. It appears the red/magenta is across the same area as the wreath...may be an alpha channel transparency problem during the RIP.[emoji57]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • Synthohol
      Certified Konica Expert
      • 5814
      what is the "auto color adjustment" you mentioned?
      did you run 3 of each gradation adjustments?
      • denvertan
        • May 2019
        • 82
        Thank you for reminding me.
        I did the Gradation Adjustment 3 times using A3 paper with few blank paper behind it to make sure it read correctly.
        • tulintron
          • Jul 2014
          • 668
          The red printout
          [ATTACH=CONFIG]46499[/ATTACH]
          The source
          [ATTACH=CONFIG]46500[/ATTACH]
          Despite saying that on another printer everything went well, I will agree with qbert69. Magenta only appears in the crown area.It may be something related to image processing. Nothing mechanical. Could have attached the job from the other printer.
          • tsbservice
            Field tech
            • 8002
            The red printout
            The source
            Other same model KM machine with same driver? Also same FW levels as offending machine?
            It appears to me also like file/software issue but you said same file is printed fine from another 4e machine which is a bit perplexing.
