C3350i and light blue stripes
    • 16391
    #16
    Re: C3350i and light blue stripes
    Scan/Copy two sided docs from DF. If first side has lines but second NOT and as you said it has lines also when using original glass then all leeds to CIS module.
    Second side of two sided originals is read from DF own CIS assy so that side being also bad is very unlikely...
    Deleted post. I misread. I thought you were talking about a kyocera 3550. My bad.
    • fatduke
      • Jun 2020
      • 75
      #17
      If you're not have the same problem when making a copy, I think you can eliminate anything in the optics as being the cause.
      Only in scans, but I will update the post with fix 'cause I contacted the dealer.
      • fatduke
        • Jun 2020
        • 75
        #18
        • Bix
          • Apr 2018
          • 1421
          #19
          As expected, these are the lines of shame. To delete them it was enough just to follow the installation manual
