C3350i and light blue stripes
  • fatduke
    • Jun 2020
    • 75
    Hi everyone,
    just recall a 1 year life C3350i with light blue stripes when scans from ADF glass or ADF.
    HD formatted, new setup from the beginning, setup correct date and time but no luck.
    I hope is not CIS either MB.
    Light blue stripes again only in scanning.
    Maybe a firmware update (FW NEEDED) could help?
    Any suggests?
    TY
  • allan
    RTFM!!
    • 5462
    Re: C3350i and light blue stripes
    Scan sample please
    Whatever
    • tsbservice
      Field tech
      • 8053
      Originally posted by allan
      Scan sample please
      Yeah...also clean the optics - CCD, mirrors, reseat board connection in scanner etc.
      • fatduke
        • Jun 2020
        • 75
        Scan sample please
        Here you are, the copy sample with blue lines all over the paper sheet.
        TY
          • 23010
          Yup, those are the "Lines Of Shame". Initializing a machine can create this situation.
          In most cases running through the electronic portion of the machine setup will recover. =^..^=
            TY
            you really need to UPLOAD PDF's of any examples jpg's are shit to look at
              wonder who does his NEW machine setups.. this is a known problem when skipping steps in the setup process.
              Good catch BC.. his samples are too small for me to view.
              USERS really need to scan in PDF format and upload to CTN
              • Synaux
                • Mar 2012
                • 1224
                Scan sample please
                Always on point, Steve!
                Talking Animals - Allan! Allan! Allan! - YouTube
                • Synaux
                  • Mar 2012
                  • 1224
                  What do you mean by USERS?
                  • Boltaction
                    • 92
                    "just recall a 1 year life C3350i with light blue stripes when scans from ADF glass or ADF."
                    I take that as the machine was installed a year ago and then the problem started which would mean it has nothing to do with incorrect setup.
                    • fatduke
                      • Jun 2020
                      • 75
                      I had a similar trouble with another machine with same blue lines months ago.
                      Called my dealer, gone trough KM Tech Service and was a CIS problem, fixed by them.
                      This is why I don't believe in INFAMOUS STRIPES OF SHAME, setup and so on (nothing personal).
                      That's it
                      Cheers
                      • Boltaction
                        • 92
                        That's it
                        Cheers
                        I've never personally dealt with "lines of shame" but I've heard the stories. I have definitely had CIS boards cause this problem for sure, though.
                        Sometimes it seems simple enough to just blame it on tech or operator error but that doesn't bring anything useful to the table.
                        • tsbservice
                          Field tech
                          • 8053
                          Scan/Copy two sided docs from DF. If first side has lines but second NOT and as you said it has lines also when using original glass then all leeds to CIS module.
                          Second side of two sided originals is read from DF own CIS assy so that side being also bad is very unlikely...
                          • Boltaction
                            • 92
                            I did not realize the c3350i had a dual scan ADF that is an awesome added feature for a smaller machine
                              • 16473
                              If you're not have the same problem when making a copy, I think you can eliminate anything in the optics as being the cause.
