DF-628 Jam sensor
  • Bix
    • Apr 2018
    • 1421
    DF-628 Jam sensor
    Hi boy,
    also today a jam with DF628. By studying various cases, I think I have identified the culprit.
    There is a piece of rubber that sticks and keeps the sensor ON all the time, causing jamming. In fact, after a cleaning, it works again. Can anyone help me find the parts code of this sensor. I can't find it in the part list
    Thanks so much!
  • Toxic
    • 698
    Re: DF-628 Jam sensor
    A143PP1Y00 Sponge
    A143PP1A01 Lever
    A143PP1B00 Torsion Spring
    A3CFPP1M01 Bracket
    A5C1M50100 Photointerrupter
      • 23008
      If that's just sponge foam, I'd probably just remove it and live with the tiny 'tic' sound. =^..^=
      • Toxic
        • 698
        Thinking about same thing @blackcat4866
        I think that "tic" sound would be inaudible besides motor and clutches noise.
        • Bix
          • Apr 2018
          • 1421
          Thanks for your help! The image deceived me because of the shape but you finally enlightened me.
          The rubbers a little scare me because in reality I do not know their real functioning. Often it is to make a noise but it could also be used to avoid upsets. I will follow your advice!
