KMBH C3350 wont send out email nor hook up to pc
  • digicor
    • Jul 2008
    • 1159
    I have a c3350 prints fine, i cant get it to send out an email, i have three inplace smtp's that i have in use, that work...that said, this c3350 will not send out, i have not done network re set yet,if i do and it still doesnt email what then? but i also would like to know where the heck is the "workgroup" setting? ive been all over this thing cant find this where to check its on workgroup or not , seem its not, but i can find where to change or check it,
    thanks
    • 30294
    Re: KMBH C3350 wont send out email nor hook up to pc
    check the gateway
    run a ipconfig
    workgroup is domain name that's not why it's not sending email
    • digicor
      • Jul 2008
      • 1159
      check the gateway
      run a ipconfig
      yes ive tried to hook up SMB and need make sure the workgroup is the setting on the MPF
        • 30294
        again not the problem
        Check gateway and Dns settings
          wonder if he knows the difference?
            • 30294
            go to YouTube deximaging help desk
            some good videos on Konica setup
            Dex Imaging HelpDesk - YouTube
            • digicor
              • Jul 2008
              • 1159
              yes i know the difference
              • digicor
                • Jul 2008
                • 1159
                fixed issue, c3350 wont connect with smb 3
                email issue resolved
                thanks for the suggestions
                • M94
                  • Jul 2020
                  • 158
                  I can't tell if you found a solution but didn't say (please do it helps us newbies cruising for info) or if the 'solution' was that the c3350 isn't capable of smb3. If you wouldn't mind clarifying I would appreciate it.
                  Glad you got it figured out either way!
                  • digicor
                    • Jul 2008
                    • 1159
                    what happened was this
                    Client changed ISP providers, TCP/IP structure changed, tech didnt re set gateway there fore print will work as data stream is going in, but not work with data stream going outbound, there fore gateway fixed, email svc fixed
                    SMB3 on win 10 and above does not recognize smb 1 or 2 , so smb scanning will not connect to older equipment and in my experience the firmware just doesn't bring the older equipment up to speed
                    it is better to use Filezilla for FTP if you absolutely need scan to folder on a older machine .
                    hope this helps you in the future
