C452 error c-11a1 with grinding noise in fs-527 finisher
  • Keenkeener
    • Sep 2020
    • 6
    I recently purchased the fs-527 finisher that includes the saddle Stitcher for my c452. When I try to print with it installed, I get a grinding noise in the finisher and error code c11a1. Any suggestions? I have another finisher that I do not get this issue with. Thanks!
  • GIUBOSS
    • 1410
    Re: C452 error c-11a1 with grinding noise in fs-527 finisher
    welcome, are you a technician or an end customer?
    -The Exit Roller Home Position Sensor (PC12-FN) is not blocked
    even after the set period of time has elapsed after the Exit Open/
    Close Motor (M6-FN) is energized (beginning of pressure opera-
    tion).
    -The Exit Roller Home Position Sensor (PC12-FN) is not unblocked
    Close Motor (M6-FN) is energized (beginning of retraction opera-
    tion).
    • Keenkeener
      • Sep 2020
      • 6
      tion).
      tion).
      im the end customer (and technician in this case only lol)
      • blazebusiness
        SanDiegoCopierRepair.com
        • 1250
        That exit roller pressure / retraction mechanism has to be able to engage and disengage. You can watch it move looking inside the paper exit area. My first step would be watch it move and try and see what is blocking or interfering with the movement causing noise.
        • Keenkeener
          • Sep 2020
          • 6
          • GIUBOSS
            • 1410
            Try lubricating the steel axes where the stapler moves. There is probably a out-of-stage section or a sensor not activated, comparison with the other functioning finisher.
            • Keenkeener
              • Sep 2020
              • 6
              Great suggestion. Nothing is jumping out at me just yet as they seem very similar.
              Where do you suggest I get a service manual for this model?
              • GIUBOSS
                • 1410
                On this site in the Request Technical Manuals and Parts section, you will be ahead if you contribute I think ...
                • blazebusiness
                  • 1250
                  You could PM me your email address if you want to for a google drive download link to the manual.
                  • Keenkeener
                    • Sep 2020
                    • 6
                    Thanks for all the help.
                    Upon further inspection, I think the worm gear is a bit worse than I thought. When I remove the motor and gear, the exit gate, door, or whatever you call it seems to move freely up and down.
                    Where would I go to find this part number and what is the best resource for purchasing this kind of part?
                    • blazebusiness
                      • 1250
                      The link I sent you includes the parts manual. With the part number you can find most parts online.
                      • Keenkeener
                        • Sep 2020
                        • 6
                        Success!
                        I replaced
                        A0HR-8044-00 22T Gear and A0HR-A896-11 Pressure Touching Alienation Motor / M9
                        and that did it. No trouble now. It was simply a couple of stripped gears.
                        Thank you for all of your help!!
                        • blazebusiness
                          • 1250
                          Success!
                          I replaced
                          Very glad you're up and running.
