Konica Minolta c220 - Black Not Showing
  • HarryBurgess
    • Oct 2019
    • 25
    [Misc] Konica Minolta c220 - Black Not Showing
    When printing both normally in test mode, C M Y are all showing as normal and printing in colour. However when attempting to print black it is barely visible, as if its just a plain piece of paper with mild shading around the page. Any suggestions would be appreciated.
  • tech51
    • 846
    Re: Konica Minolta c220 - Black Not Showing
    There are a few things that can cause this such as hv failure, but a common one on this model is a slipping or failed black dev clutch.
    I would check the dev unit is rotating before I went any deeper on this fault.
    • HarryBurgess
      • Oct 2019
      • 25
      Thanks for this information, I've checked and the dev unit is rotating. What would be the simplest way to change the developer clutch if you don't mind me asking?
      Also, is the clutch on the developer itself or inside the copier?
      • and
        • Oct 2011
        • 97
        Inside
        • copyman
          Owner / Technician
          • Sep 2005
          • 4721
          See if black dev is on mag roller. If drum is overlife it can short out and devolper is pulled and dumped into waste toner box. More common on the "4" series but can also happen to the C220 series.
