Bizhub 4750 stuck on logo
  • Zesti
    • Jun 2009
    • 308
    Hi guys,
    This machine with one of my friend stuck on logo. Any idea?
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Re: Bizhub 4750 stuck on logo
    Originally posted by Zesti
    Hi guys,
    Firmware can cause this, bad hdd can also cause this. Or bad boards.
    Can you can get into service mode?
    Have you tried turning ON the power switch while pressing the power key and start up [Extra Service Mode] and then installing firmware?
    If you can get in----first install sub firmware and then main firmware in that order.
    • Bix
      • Apr 2018
      • 1421
      Sometimes it is enough to keep the network cable disconnected
