Exporting/importing SMB shares, new location
  • pstoric83
    • Mar 2020
    • 34
  • Synthohol
    Certified Konica Expert
    • 5900
    Re: Exporting/importing SMB shares, new location
    backup the machines addy book and settings, set aside (just in case)
    DL the addy book in .csv, open in Excel and do a find and replace from old servername/IP to the new one.
    save.
    import to copier.
    exactly. you got it.
    • escalante
      • Sep 2018
      • 115
      In the following link it mentions on the subject of:
      Exporting information to an SMB sharing folder
      Saving the setting information of this machine (Export)
      Enviado desde mi SM-J701M mediante Tapatalk
      • pstoric83
        • Mar 2020
        • 34
        save.
        import to copier.
        Thanks! Will passwords need to be re-entered manually after or will they import too?
        • Synthohol
          • 5900
          just use the same passwords on the new server
            • 37605
            If Konica is like Ricoh and saves their address book to the HDD, you might want to save those backups just in case.
            • emujo2
              • Mar 2017
              • 1579
              Trying to ward off what I think is going to be a problem for you...C454 was out around Server 2008 (or even earlier) If you are upgrading to anything current you will not get these C454 to scan to SMB without lowering the server security (SMB 1.0) I would hope you have taken tbis into account, E
              • pstoric83
                • Mar 2020
                • 34
                Yea unfortunately I have SMB 1.0 enabled still but I was hoping to phase it out after this server migration. I made a mistake on the model though. The models at this office are two Bizhub 808's and a 458. The firmware seems newer on these so hopefully the will allow me to disable SMB 1.00
                • tsbservice
                  Field tech
                  • 8056
                  With these models you should have no problems with disabling SMBv1.
                  • pstoric83
                    • Mar 2020
                    • 34
                    FYI I didn't have to re-enter the passwords. They imported just fine. Easy.
                      • 37605
                      Synthohol was referring to the new server. Depending on what OS version the old server was running, Active might not be able to migrate all user information.
                      • pstoric83
                        • Mar 2020
                        • 34
                        Server 2019 Standard...
