Import/Export address book from C308 to C300i
  • copier tech
    • 8174
    [Misc] Import/Export address book from C308 to C300i
    Quick question, i'm upgrading my client with a C308 to a new C300i so is it possible to transfer the address book?
    Don't think I've tried, i'd like to use the USB method.
  • Leyahné
    • Feb 2016
    • 44
    Re: Import/Export address book from C308 to C300i
    You need to set the soft switch in service mode and then in admin mode transfer to export to USB
    Sent from my SM-N960F using Tapatalk
    • emujo2
      • Mar 2017
      • 1579
      Page Scope Data Admin will do the same..Pretty handy tool as long as you keep it updated. E
      • copier tech
        • 8174
        Yeah SW72 HEX 04.
        I believe on the 8 series this is set by default.
        • Leyahné
          • Feb 2016
          • 44
          Use this
          • srvctec
            Former KM Senior Tech
            • Oct 2009
            • 827
            I've had the USB method not work sometimes so I usually just use Pagescope Data Admin. I just imported all access codes/accounts and one-touches from a C220 (no USB backup option) to a C550i using PDA the other day. Worked like a charm.
            Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
            • copier tech
              • 8174
              Thanks thats good to know!
              • mascan42
                • Oct 2008
                • 485
                Address book works fine, but don't try to do network settings or anything like that by USB. The i series stores that data differently, and I've seen machines lock up because it doesn't recognize the data.
                • copier tech
                  • 8174
                  Use this
                  The menu layout is different on the i series, but is the import section in the same place?
                  • copier tech
                    • 8174
                    Import/export worked fine via Pagescope which was a bit help as there were around 50 SMB entries this saved me a lot of time!
