Bizhub C220 Setup
  • DM2-Inc
    • Sep 2020
    • 6
    Bizhub C220 Setup
    I purchased a Konica Minolta Bizhub C220 from a company closing it's doors due to COVID.
    I'm an end-user, not a technician, but I setup network systems, so believe I can handle some of what I need to do to get this copier working.
    I've set it up in my home office, because now I'm working from Home due to COVID, and thank full I still have a job.
    The unit has:
    DF-617 Reverse Automatic Document Feeder
    EK-604 Local Interface Kit
    PC-207 Paper Feed Cabinet
    SD-509 Saddle Sticher
    FS-527 Finisher
    PK-517 Punch Kit
    JS-603 Job Separator
    Question:
    1. I've seen several "Installation" sheets, on this web site, that have 10 to 20 pages to them. These appear to be for initial setup of the printer. I've downloaded some 20 manuals from Konica Minolta's web site, and have Parts manual and Service manual. Are there individual Installation sheets for the various above parts that I should be looking for?
    2. The Paper Feed Cabinet has 11 x 17 paper in Tray 3, but every time I print, It always says it's A3 paper. I thought I set this up using the printers web interface, but I always have to override this when I print. I've looked for a manual on the control panel and how to use it, but Can't find one...How do I set this up?
    Thanks in Advance
    Dan Marr
    • 30296
    Re: Bizhub C220 Setup
    The unit has:
    FS-527 Finisher
    PK-517 Punch Kit
    Question:
    Thanks in Advance
    Dan Marr
    Print driver should be pcl6 Not the Universal driver and select the c220 it should add any features
    2nd check the paper tray guides the most common problem you can manually set the paper tray to 11 by 17 under the paper tray setting on the operational panel user settings
    • copyman
      Owner / Technician
      • Sep 2005
      • 4723
      The unit has:
      FS-527 Finisher
      PK-517 Punch Kit
      Question:
      2. The Paper Feed Cabinet has 11 x 17 paper in Tray 3, but every time I print, It always says it's A3 paper. I thought I set this up using the printers web interface, but I always have to override this when I print. I've looked for a manual on the control panel and how to use it, but Can't find one...How do I set this up? You are correct have to change paper tray to 11x17 at copier control panel, "touch auto paper",select tray 3, "change setting", 11x17
      Thanks in Advance
      Dan Marr
      Not sure how you were able to get into the dealer side of Kon/Min and get the service and parts manuals but good to have for codes, etc.
      There are many "user" manuals on the regular Kon/Min website. The service manuals don't get into using the machine, user settings, control panel buttons, etc. You will find all of this in the operators & advanced operator manuals.
      That is a good machine so should work well for you.
      Best of luck with it.
      • DM2-Inc
        • Sep 2020
        • 6
        Copyman
        The service manual I have is version 1.0, and is dated 2009.07, so it might be a bit dated, but it should have what I need.
        As far as the manuals go, what I have is below, but I don't have one titled "...operators & advanced operator manuals..." You don't have a link to it do you?
        The numbers are simply the order they appeared on the Web site...
        • Konica Minolta 01 - Driver Packaging Utility User's Guide
        • Konica Minolta 02 - HDD Backup Utility User's Guide
        • Konica Minolta 03 - Bizhub C360, C280, C220 Log Management Utility User Guide
        • Konica Minolta 04 - User's Guide - License Install Utility
        • Konica Minolta 05 - User's Guide - Setup Utility for Right Fax
        • Konica Minolta 06 - Device Set-up User's Guide
        • Konica Minolta 07 - Bizhub C360, C280, C220 User's Series PKI Security Operations
        • Konica Minolta 08 - Bizhub C360, C280, C220 User's Guide AU-211 Authentication
        • Konica Minolta 09 - Bizhub C360, C280, C220 User's Guide AU-201H
        • Konica Minolta 10 - Bizhub C360, C280, C220 User's Guide MS Office SharePoint Server 2007
        • Konica Minolta 11 - Bizhub C360, C280, C220 User's Guide Network Admin
        • Konica Minolta 12 - Bizhub C360, C280, C220 User's Guide Trademarks Copyrights
        • Konica Minolta 13 - Bizhub C360, C280, C220 User's Guide Box Operation
        • Konica Minolta 14 - Bizhub C360, C280, C220 User's Guide Network Scan, Fax Operation
        • Konica Minolta 15 - Bizhub C360, C280, C220 User's Guide Printing
        • Konica Minolta 16 - Bizhub C360, C280, C220 User's Guide Enlarge Display Oper
        • Konica Minolta 17 - Bizhub C360, C280, C220 Quick Guide Copy, Print, Fac Scan, Box
        • Konica Minolta 18 - Bizhub C360, C280, C220 User's Guide Fax Driver
        • Konica Minolta 19 - Bizhub C360, C280, C220 User's Guide Copy Operation
        • Konica Minolta 20 - Bizhub C360, C280, C220 User's Guide Advanced Features
        • Konica Minolta 21 - Bizhub C360, C280, C220 User's Guide Security Operations
        • Konica Minolta 22 - Bizhub C360, C280, C220 User's Guide License Authentication Operation
        • Konica Minolta 24 - Bizhub C360, C280, C220 Using the Machine
        • Konica Minolta 25 - Bizhub C360, C280, C220 Pocket Guide
        • Konica Minolta Bizhub C220 DF-617 Reverse Automatic Document Feeder
        • Konica Minolta Bizhub C220 Installation Manual
        • Konica Minolta Bizhub C360, C280, C220 Parts Guide
        • Konica Minolta Bizhub C360, C280, C220 Poster
        • Konica Minolta Bizhub C360, C280, C220 Quick Guide
        • Konica Minolta Bizhub C360, C280, C220 Service Manual - Field
        • Konica Minolta Bizhub C360, C280, C220 Service Manual - for PKI Card System
        • Konica Minolta Bizhub C360, C280, C220 Service Manual - Theory of Operation
          • 30296
          Copyman
          • tsbservice
            Field tech
            • 8020
            If you don't need advanced finishing options, just use DF and paper feed unit, not so much hassle to connect them. Imho first test main unit before even start adding options.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4723
              Copyman
              Looks like you have every manual. You can definitely find things like changing tray 3 paper size, how to use control panel, etc. in those manuals.
