Konica minolta C3080 fusing Lower roller line
  • Jayson
    • Apr 2020
    • 5
    Hi guys,
    I have a problem with konica minolta C3070 when printed solid color .
    The problem is fusing lower roller scratch line cause by fusing separation claws ,even new fusing unit itself also have already .If without claws thin paper will paper jam .
    WhatsApp Image 2020-09-22 at 20.44.49.jpgWhatsApp Image 2020-09-22 at 20.44.57.jpg
    Any solution on this ?
    Thanks you
  • uros.service
    • Sep 2020
    • 4
    Re: Konica minolta C3080 fusing Lower roller line
    Originally posted by Jayson
    Hi guys,
    [ATTACH=CONFIG]46844[/ATTACH][ATTACH=CONFIG]46845[/ATTACH]
    Thanks you
    Hello,
    Change the claws. KM have a modification.
    • Jayson
      • Apr 2020
      • 5
      Originally posted by uros.service
      Hello,
      so far i never receive any modification claw .Do you have part ?
      • konicavod
        • Feb 2020
        • 27
        A50UR72U11
        • Jayson
          • Apr 2020
          • 5
          Originally posted by konicavod
          A50UR72U11
          Now currently we using this one cause the problems 😔
          • Lordnixon
            • Jul 2017
            • 18
            TAD(English).pdf
            You can try it (A4EU747501)
              • 22916
              Originally posted by Lordnixon
              [ATTACH]48465[/ATTACH]
              So to be clear, you remove the original lower claws and replace them with this separation sheet?
              And, this solution jams more often on lightweight media and images with heavy fill to the voids?
              • Lordnixon
                • Jul 2017
                • 18
                yes(
                customer was not satisfied with this option. It was not possible to check in practice.
                But it's like a fuser sheet in C6000/7000
                • Wakawaka
                  • Jul 2022
                  • 3
                  I've had some success with buffing out the lines on the lower heat roller with a bit of alcohol and then buffing it out with a dry soft cloth. I've also removed the three middle lower fuser roller claws for the moment so that I can test whether this will help with the lines on the lower roller going forward. I'm going to monitor for any potential jamming issues with the claws removed and will let everyone know if this helps long term with these lines.
