458e shuts down during job
  • mascan42
    • Oct 2008
    • 485
    I have a 458e that a couple of times a day just stops in the middle of a job. The control panel goes blank, the start button alternated blue ad orange flashing, and the activity light continues to flash. I can hear fans running, but nothing else. The only way to get it back is to reboot the machine.
    I already rewrote the firmware (G00-X8) and had no effect. SSD seems to think it might be a loose connection to the control panel, but that shouldn't make the engine shut down (they're even more useless than usual now that they're working from home). Any ideas?
    BTW, this is a fairly new machine, only a few weeks old.
  • tsbservice
    Field tech
    • 8020
    Re: 458e shuts down during job
    Think I would start from Initialize All just in case anything is corrupted. Also I had cases(not KM) where corrupt file causes printer to restart in the middle of print job, I mean to check if this happens from different PCs and jobs. Any errors in log?
    • mascan42
      • Oct 2008
      • 485
      There are no error codes in the history, and it's not a corrupt job because it also happens during copy jobs.
      • emujo2
        • Mar 2017
        • 1579
        maybe nothing in servcie mode error history, but check your Instantaneous power failer counters..Possibly you are dropping power, or brown out..A corrupt print job should lock the machine up, not re boot it. And a copy job should never re boot the machine.Could also be an intermittent short/ground with the engine. This would happen during print/copy. E
          • 16406
          Originally posted by emujo2
          maybe nothing in servcie mode error history, but check your Instantaneous power failer counters..Possibly you are dropping power, or brown out..A corrupt print job should lick the machine up, not re boot it. And a copy job should never re boot the machine.Could also be an intermittent short/ground with the engine. This would happen during print/copy. E
          I co-sign this. Also measure the voltage at the power outlet. Could be low.
          • MarioTech
            • Jul 2020
            • 48
            • mascan42
              • Oct 2008
              • 485
              Instantaneous power failure counters? Do you mean on the ESP power filter?
              • Synaux
                • Mar 2012
                • 1224
                Is this a new feature on the 8 series? Or is that the one that just says "Shutdown?"
                Perform a I/O check on everything in SM.
                • Bix
                  • Apr 2018
                  • 1421
                  Are you sure the problem is the printers? I have had several customers with UPS. The ups was not powerful enough and caused the printer to shut down as soon as someone launched a job.
                    • 23009
                    I've seen this situation. The UPS usuals squeals at you ever time you wake up the machine, and fuser errors. =^..^=
                    • emujo2
                      • Mar 2017
                      • 1579
                      We rarley, if ever, put a MFP on a UPS..surge supprssor always, but the size of a UPS required to keep an MFP running is pretty big..Instantaneous power failures..in Service mode under counters..Would indicate a problem with wall voltage or the surge supporessor itself. E
                      • Bix
                        • Apr 2018
                        • 1421
                        In other cases it was the faulty power strip (in the manual it is forbidden to connect to these devices but 50% of customers ignore this rule). It did not support printer loading.
                        • mascan42
                          • Oct 2008
                          • 485
                          There are no errors listed on the instantaneous power failure counters. A handful of power surges recorded on the power filter, not sure if they line up with the shutdowns or not. I'll have to download the data off the power filter to be sure.
                          • t85ster
                            • Mar 2015
                            • 39
                            Never plug copiers into the Battery Backup outlets on a UPS. Only use the "Surge Protection Only" outlet. The internal battery can't properly supply the current load of a copier or laser printer. My 2 cents...
                              • 23009
                              There are UPS devices that can support a copier, but they are not cheap. A 15A copier requires 1800Watts (P=IV) capacity. The typical computer battery backup is rated at 500Watts. We have successfully used UPS devices on Kyocera devices to overcome power deficiencies. You can watch the power monitor LED flicker On each time the MFP fires up. =^..^=
